Bending Rolls & Bead roller
Home › Forums › Workshop Tools and Tooling › Bending Rolls & Bead roller
  • #50582
    Staffdog
      @staffdog
      Hello All,
       I have just completed a 325mm metric Geared version of the George Thomas Bending rolls from M.E.
      All on cnc ,I have done a new Drawing & 3d model in Turbocad,also all nc / toolpath files for 4 axis mill & 2 axis lathe.If they are of use to anyone please let me know & can provide.
      I will post some pictures over the weekend
      Also have a couple of questions
      Q 1, is there somewhere on forum to post project files ?
      Q 2, I am looking for plans for a BEAD Roller can anyone point me in the direction of any.
      Regards Adrian
      #16547
      Staffdog
        @staffdog
        #50619
        Gray62
          @gray62
          Hi Adrian, I am just about to build a set of bending rolls along the line of the GH Thomas design, I would really appreciate a copy of your Turbocad drawings
          regards
          Graeme
          #51693
          Gray62
            @gray62
            Just been pgoing through my old copies of MEW, there was a design in issue 33 for a ‘jenny’ bead roller if that helps.
            regards
            Graeme
            #51718
            Ian S C
              @iansc
              There were some articals in ME by a bloke who was building replica vintage bikes, and there was a bit about the gear he built for rolling the rims.Ian S C
              #51725
              Staffdog
                @staffdog
                Hi all,
                1st a quick apology for tardy response not been on here for a while been away with work
                thanks for help locating a design.
                Graeme if you pm me i will send you my drawings & some assembly pictures,do you want the cam files ?. drawing in TCad v12.3 format or do you want  other format.It’s quite a big file with all data.
                Does anyone have an answer for my other question regarding a file repository for user to upload project files.Personally i have no problem sharing any of my project info if it helps someone somewhere.So i files section like a yahoo group seems a good idea !
                regards Adrian
                #51779
                Digger DG
                  @diggerdg
                  Staffdog, sent you PM yesterday requesting drawings and assembly pictures.  Thought I would post also as I ask for the drawings in AutoCad instead of TCad.  I also have Rhino3D and PartMaster.  Any of these are OK, howerer prefer AutoCad if you can save to that format.  The slip roller design appears to be just what I’m looking for.
                  I’m a new member to Model Engineer.  I’ve CNC’ed a RF-31 mill/drill and a Grizzly G0602 lathe.  Mostly I have made things to make more things on each.  Looking forward to being an active member of Model Engineer Workshop.
                  Regards, Doug
                  #51783
                  Digger DG
                    @diggerdg
                    Posted by Staffdog on 10/04/2010 09:20:10:
                    Hello All,
                    Regards Adrian
                    Adrian,
                    Do a search on the Web for Bead Roller and you’ll find numerous hits.  One site with plans is http://sites.google.com/site/scanmant/home .  I built the Ring Roller and the Broach Press from his plans.  The Bead Roller seems to offer several options not usually found.  Hope this helps.
                    Doug
