Bending 1/8 pipe
Bending 1/8 pipe
Home › Forums › Locomotives › Bending 1/8 pipe
  • #1593
    Paul Sweet
      @paulsweet31847
      Bending pipe
      #286432
      Paul Sweet
        @paulsweet31847
        hello can any one suggest how to bend some 1/8 pipe just after the nipple at right angles without crushing it. Thanks.
        #286490
        RichardN
          @richardn
          You can get tiny little bending springs which could work, although using the correct size is important as an undersized spring still lets the pipe crumple a touch which ruins the effect or causes small splits- or have you ever tried using Woods metal as a filler instead?
          Edited By RichardN on 28/02/2017 19:59:48
          #286492
          RichardN
            @richardn
            Looks like a cheap set of springs including 1/8"… no guarantees of quality, usual disclaimer etc..!
            Brian H
              @brianh50089
              I've not heard of Fields metal, is it similar to Woods metal ,which has a melting point just below the temperature of boiling water?
              If silver soldering after it is vital to remove ALL traces of the Woods metal. If soft soldering it's not so vital but as much as possible should be removed.
              #286494
              RichardN
                @richardn
                No idea where I got fields metal from- absolutely right, I meant Woods metal (and changed original post)… I bought a small ingot of woods metal but then found the uni workshop had springs I could borrow and never tried it… I think there are different flavours of woods metal with compositions including or not cadmium etc which may effect melting point and availability..?
                #286496
                HOWARDT
                  @howardt
                  Why not make a stem elbow and solder the pipe into it.
                  #286498
                  malcolm wright 1
                    @malcolmwright1
                    Fields metal is a non toxic alternative to Woods metal as it contains no Lead or Cadmium.
                    #286501
                    Simon Collier
                      @simoncollier74340
                      Make a groove in something like 3/8 brass bar with a parting tool 1/8 deep and 1/8 wide, anneal pipe and bend around groove. Cut the pipe close to the corner and solder on nipple. Not 90 degrees obviously but as tight a turn as you'll get without making a special fitting. I am amazed how often there is no room and you want the tightest turn possible.
                      #286502
                      stephen goodbody
                        @stephengoodbody77352
                        Hello Paul,
                        Generally it's best to start with a longer length of pipe than you need, make the bend, and then cut the pipe back to where you want your nipple to be. If the nipple is already soldered onto the pipe then the job is more difficult because you have less leverage for bending.
                        Assuming this is copper, the way I normally do it is to make a simple slotted mandrel from a piece of scrap brass rod. Chuck a length of rod in the lathe and machine a slot a tiny bit wider than the pipe diameter and to a depth of at least 3/32" but preferably 1/8" deep. The width of the slot should be such that your pipe slips in and out of the slot easily but doesn't waggle around. The root diameter at the bottom of the slot should be your bend's desired inside radius. If in doubt, err on the side of a slightly smaller root diameter.
                        Anneal the pipe where you want the bend to be, put it into the slot, and gently push with your fingers to start the bend. As soon as the pipe begins to work harden (stiffen) gently ease it out of the mandrel and re-anneal. Repeat until the bend is finished to your satisfaction.
                        The above works because a pipe can only flatten in one direction if it can simultaneously stretch in another. The side walls of the slot prevent the pipe from widening and hence prevent the pipe from flattening. The pipe will tend to want to stick in the slot, especially if you bend too much between annealings, so beware. An improvement on the above is to make a two-piece mandrel where one half screws into the other to leave the 1/8" slot between. You can then partly unscrew one side of the mandrel to remove the pipe after each bend, overcoming the potential problem of the pipe jamming in the slot and being difficult to remove after bending.
                        Good luck,
                        Steve Goodbody
                        Edited By stephen goodbody on 28/02/2017 21:01:18
                        #292653
                        Henry Artist
                          @henryartist43508
                          Tube bending springs are largely a complete waste of time unless you want very gentle complex bends.
                          For bending 1/8" tubing, small pipe benders like this – **LINK** – are much better. They were originally sold for bending vehicle brake pipes but have found favour with those who build small steam engines. They are available EVERYWHERE and prices vary wildly.
                          For really tight bends I also use DuBro pipe benders. Available from all good Radio Control model shops. I can even bend thin wall K&S tubing with them. Just remeber to anneal the pipe before you try to bend it.
                        Home › Forums › Locomotives › Topics
