Bench Covering?
Bench Covering?
Home › Forums › General Questions › Bench Covering?
  • #323355
    Andrew Tinsley
      @andrewtinsley63637
      A short time ago, there was a thread discussing lino material as a work bench covering
      I am now unable to locate it. I am just erecting a bench and would like to cover the thick plywood top with a lino type material as was done in the past.
      Especially where can you buy this type of covering?
      Andrew.
      #25582
      Andrew Tinsley
        @andrewtinsley63637
        #323363
        David Colwill
          @davidcolwill19261
          Not sure about lino but I used this **LINK**
          which has been OK.
          Regards.
          David.
          #323364
          David Standing 1
            @davidstanding1
            Any decent carpet shop!
            #323369
            David George 1
              @davidgeorge1
              At work we always covered the bench tops with oil tempered hard board about 3/16 thick tacked on and under vice etc replaced it most Christmas just before we broke up.
              David
              #323370
              ASF
                @asf
                #323372
                MW
                  @mw27036
                  Posted by Andrew Tinsley on 24/10/2017 21:31:43:
                  Andrew.
                  My dad's garage has a quite old workbench which is covered with that stuff. I'd have no clue where to get it from.
                  #323382
                  John McNamara
                    @johnmcnamara74883
                    I prefer MDF or hardboard coated with a couple of thick coats of one pack semi gloss clear urethane. By thick I mean poured on then brushed smooth using as much as the surface can carry without running off.
                    It works really well in three days it is very hard and durable.
                    Edited By John McNamara on 25/10/2017 04:45:13
                    #323410
                      Andrew.
                      A friend gave me a sample of Hospital flooring which was much heavier than any lino I've ever seen in a shop. I tried to find a source to do my kitchen floor and failed miserably. It doesn't seem to be available retail for DIY; the expectation is that it's bought as part of an outfitting package, which would be OTT for covering a bench.
                      My local happens to be a large Teaching Hospital. It's a constant building site and more than once I've noticed lino off-cuts dumped in a skip that would be big enough to do a bench .
                      not done it yet
                        @notdoneityet
                        I think the post was likely about summat else but digressed to material scavenged from naval vessels. There again, that could have been on another forum….
                        #323420
                        David Standing 1
                          @davidstanding1
                          Posted by not done it yet on 25/10/2017 10:02:22:
                          The original thread is linked by ASF above smiley
                          #323424
                          Alan Jackson
                            @alanjackson47790
                            I have a rubber car mat on one half of the bench and the other half covered with a piece of carpet. The carpet is useful for dismantling parts as they stay where they are, it also is a good soft surface for filing small parts etc.
                            Alan
                            #323431
                            Bikepete
                              @bikepete
                              Posted by SillyOldDuffer on 25/10/2017 09:37:28:
                              Bits of industrial/safety vinyl are available on Ebay – search for e.g. "safety flooring roll end". Altro seems a good brand – I got some for my kitchen recently. Definitely much heavier duty than the 'normal' vinyl that was there before.
                              Edited By Bikepete on 25/10/2017 10:46:20
                              #323451
                              not done it yet
                                @notdoneityet
                                Not the one I was thinking about,. Sorry!
                                #323457
                                John Smith 13
                                  @johnsmith13
                                  I live in the States and found sheets of hardboard coated with a white plastic coating like whiteboards in offices. I use this on my bench and like how it is easy to clean and any small items are easily seen on the bench. Temporary sketches or calculations can easily be done in felt tip pen and wiped away when they are no longer needed.
                                  Andrew Tinsley
                                    @andrewtinsley63637
                                    Thanks everyone,
                                    It looks like the thick lino material that I am thinking of is unobtanium from normal retail outlets. I will try Ebay for some roll ends as suggested.
                                    Andrew.
                                    #323494
                                    KWIL
                                      @kwil
                                      #323502
                                      Brian G
                                        @briang
                                        Or perhaps 2.5mm or 3.5mm linoleum sold by the metre? **LINK**
                                        I must admit it has me tempted, my dad's bench was covered in linoleum and was tough but didn't bruise anything placed on it.
                                        #323509
                                          My dad did TV rentals. He had some mats that were like thin lino with a fleecy layer on the other side. He used them in his van as they stopped TVs getting scratched up.
                                          #323656
                                          John Reese
                                            @johnreese12848
                                            I am using 1/4" conveyor belt. Very durable.
                                            #324160
                                            Stewart Mason
                                              @stewartmason95803
                                              From experience at work, best workbench surface I ever used was inch thick chipboard covered with formica sheet. Very hard wearing, wipe clean, looks smart. (it wasn't a kitchen worktop). Our bench tops were about 5' by 10' and we used a kind of light green colour. Easy to see stuff when you dropped it. Our new bench tops are 3 inch marine ply covered in 3/16 ish white perspex. It too is very good. We clean it down with brake cleaner spray, or sometimes just a water spray bottle with a few squirts of washing up liquid. On those we service and repair every thing that can be carried on a Fire Appliance, and they still look good as new after over 18 months hard use. With the white tops once we tidy up and wipe down, the place looks as clean as a laboratory.
                                              #324375
                                              Robin
                                                @robin
                                                I did a packing bench with hospital grade linoleum, had to stand a lot of Stanley knife on brown paper action. I just went into town and bought the lino. Mind you that was 30 years ago smiley
