BCA jigborer motor
BCA jigborer motor
Home Forums Manual machine tools BCA jigborer motor
Viewing 2 posts - 26 through 27 (of 27 total)
  • #514568
    John Baron
      @johnbaron31275
      Posted by Matt Mackeson on 20/12/2020 11:42:25:
      Thank you all for the comprehensive replies. I don't think I have ever had such a quick and thorough set of replies to any post on any other forum!
      I took the access plate off and found this handy wiring diagram for the two speed switch. If I understand this correctly the motor uses both star and delta for the two speeeds?
      So it seems I have three options:
      • a new dual voltage 3ph with a VFD and adapter plate
      • a rotary phase converter
      • Look further into the VFD's posted by John. From what I understand this would give me a single speed on the current motor but then give me speed control through the vfd?
      I am learning a lot about electric motors through all this so thank you all again for the help!
      Hello Matt,
      Unless I've misunderstood you, the motor would normally only be supplied from a single 380/440 three phase supply. The VFD that I pointed to, will behave in exactly the same way as any other VFD ! So yes you will have the ability to control the speed as you wish.
      Only one caveat do not change the motor speed whilst under power. The VFD has to be switched off before changing speed by using the machines own switch. You will damage the VFD if you forget.
      That motor will not run at full power on 230 volts even via a 230 volt single phase input VFD with 230 volts three phase output. You will still get the two speeds but only half or less of the HP.
      HTH.
      Edited to correct wording !
      Re edited to add these VFD's are so cheap that the cost between 1 and 2 HP is very little.
      Edited By John Baron on 20/12/2020 16:29:26
      Edited By John Baron on 20/12/2020 16:32:23
      Matt Mackeson
        @mattmackeson
        Posted by John Haine on 20/12/2020 15:48:07:
        What power is your motor? But a 0.75 kW VFD should be ok I think.
        The motor is 0.5hp, so 0.37kw
