During a previous life as an x-ray service engineer I was tasked with changing a high voltage "tank" in a hospital x-ray room that had developed an internal switching fault. (This was basically a large steel tank filled with oil and containing a high voltage transformer and switch gear.) The installation was ancient (valves and relays etc) and consequently the company had to source from somewhere in the Balkans.
I followed the standard procedures for setting the correct waveforms for the tube output and had set the oscilloscope to trigger on the final test at maximum current and voltage. As I pressed the exposure switch there was an incredible bang and a blinding flash from the control console that I was kneeling behind. The full output of 30kW @125kV had shorted inside what turned out to be a faulty tank with the result that part of the control cabinet was damaged.
My eyesight returned to normal quite quickly and the ringing in my ears subsided, but my bowel problems persisted for some time!
Gordon
