BA sizes
BA sizes
Home › Forums › Beginners questions › BA sizes
Viewing 25 posts - 1 through 25 (of 89 total)
  • #544314
    Dr. MC Black
      @dr-mcblack73214
      I have nut spinners for 0BA, 2BA and 6BA but I have NOT been able to purchase a nut spinner for 4BA (at a reasonable price).
      I have looked at the data, and that suggests that 4BA is very similar to 1/4 inch A/F
      Is this a reasonable inference?
      MC
      #10830
      Dr. MC Black
        @dr-mcblack73214
        Is 4BA the same as 1/4 inch hex?
        #544315
        John Haine
          @johnhaine32865
          Have you got a caliper? If so measure it.
          #544317
          Colin Harwood
            @balljoint
            4 BA is 0.248, so near as you can get
            #544319
            Mark Rand
              @markrand96270
              Across flats for 4BA hexagon is 0.249", so fairly close to 1/4" cheeky.
              #544321
              Mark Rand
                @markrand96270
                Looks like ±1 thou according to sources…
                #544329
                Nigel Graham 2
                  @nigelgraham2
                  I'm a bit surprised you could not find BA nut spinners or similar. Have you tried Chronos or ModelFixings? They may have them.
                  #544330
                  Former Member
                    @formermember12892
                    #544333
                    John Haine
                      @johnhaine32865
                      Get an imperial Allan head bolt with 1/4" socket.
                      #544346
                        Posted by John Haine on 10/05/2021 21:25:53:
                        … or just use the handle from a 1/4” hex drive screwdriver set
                        Dr. MC Black
                          @dr-mcblack73214
                          Posted by Nigel Graham 2 on 10/05/2021 21:14:34:
                          I have tried both; Chronos does NOT sell nut drivers and Model Fixings do NOT have BA sizes in their range – only metric.
                          But Very many thanks for the suggestion.
                          #544351
                          Dr. MC Black
                            @dr-mcblack73214
                            I have tried using a 1/4" screwdriver bit handle but the 4BA nuts do NOT seem to be a consistent size. Some fit but others do not, even though they all have a 4BA thread.
                            Can anybody tell me what size Cap head screws have a 1/4" socket in the head, please?
                            #544352
                            Bill Phinn
                              @billphinn90025
                              Posted by Dr. MC Black on 11/05/2021 01:10:13:
                              Some 5/16" UNC and UNF have a 1/4".
                              #544356
                              Speedy Builder5
                                @speedybuilder5
                                Make your own up, bit of tube (drilled out to the suit), heat it up and force some steel 4BA nuts down the tube, adjust the fit by hammering to shape. That way, you can make them "deep" to accommodate nuts that are spun onto threaded rod further than the "normal" amount.
                                I have used car radio Ariel telescopic tube for 8 and 10 BA tubular spanners.
                                Bob
                                #544357
                                  If some of the hexagons are over-size, then it seems you are ‘on a hiding to nothing’
                                  … You need to find whatever wrongly sized socket happens to fit them.
                                  Edit: __ maybe useful link
                                  https://www.ba-bolts.co.uk/faq.html
                                  Edited By Michael Gilligan on 11/05/2021 06:51:42
                                  #544359
                                    Get a 4BA box spanner and Loctite or solder on your own extension handle.
                                    4 BA socket and a 1/4" drive "screwdriver" handle work for me in most cases changing to a box spanner if room is tight.
                                    Edited By JasonB on 11/05/2021 07:15:45
                                    #544367
                                      Here’s another useful reference page: **LINK**
                                      https://www.fastenerdata.co.uk/fasteners/nuts/hexagon-full/ba/ba-hexagon-full-nut-brass-bs57.html
                                      Note that there is a common theme emerging :
                                      Anything greater than 1/4” AF is not compliant with BS 57:1951  and is therefore ‘out of spec.’
                                      There, of course, is no law against making ‘specials’ … but you must expect to need a special spanner.
                                      Ref: https://shop.bsigroup.com/ProductDetail?pid=000000000000010735
                                      Edited By Michael Gilligan on 11/05/2021 08:11:25
                                      #544383
                                      Dr. MC Black
                                        @dr-mcblack73214
                                        Posted by Michael Gilligan on 11/05/2021 06:50:30:
                                        Thank you for taking the time to post.
                                        Actually the nuts are smaller than the 1/4 driver.
                                        The BA-bolts data is interesting – on both of the sites for which links are provided, the figures are in inches – but I was told years ago that BA is actually defined in Metric.
                                        When I find useful data, I like to print it, laminate and keep in workshop. Sadly both the tables are NOT in an easily printable format.
                                        With best wishes and thanks again.
                                        MC
                                        #544414
                                        MadMike
                                          @madmike
                                          Ebay has plenty of 4BA nut spinners. However if you have hex heads that do not conform then check that you have a genuine BA bolt. You may find that some of todays suppliers fo bolts are using a more readily available metric or Imperial A/F hexagon bar. I have 4BA open ended, ring and box spanners and they all are perfect fits on genuine 4BA hex heads. If you find nut spinners do not fit then try a long reach box spanner which will probably be 4BA one end and 2 BA the other.
                                          BA threads are originally based on the Swiss or Thury thread with a thread included angle of 47 degrees and 30 minutes. Thus the thread depth is less that the 55 degree Whitworth thread form. HTH.
                                          #544416
                                            Posted by Dr. MC Black on 11/05/2021 10:04:41:
                                            Apologies … I misunderstood your “Some fit but others do not …”
                                            It is not uncommon for BA nuts and bolts to be supplied with under-size spanner flats.
                                            As regards the BA system calculations: Yes, the calculation was derived from an existing metric system; but the British Association for the advancement of Science was Imperial to the core !!
                                            P.S. __ BS 57:1951 actually tabulates all the values in both systems of units.
                                            Edit: this is worth a look:
                                            https://en.wikipedia.org/wiki/British_Science_Association
                                            Edited By Michael Gilligan on 11/05/2021 13:19:57
                                            #544419
                                            elanman
                                              @elanman
                                              Are some of the nuts made with the one size smaller hex bar to make the nuts look more in scale. So a 4BA nut would be made with a 5BA hex size. Kennions still sell these and also bolts.
                                              Cheers
                                              Former Member
                                                @formermember12892
                                                #544422
                                                elanman
                                                  @elanman
                                                  Cheers
                                                  Dr. MC Black
                                                    @dr-mcblack73214
                                                    Very many thanks to everybody for their comments
                                                    I will manage with a 1/4" Screwdriver Bit handle for the time being.
                                                    The cost of postage often makes buying things from Ebay uneconomic – apart from NOT knowing if any descriptions are fair and accurate.
                                                    I recently bought a book from an overseas bookseller – although he described it as "Acceptable" many of the pages had been scribbled on and I told him that a fair description would be "Poor". The stress of doing this has convinced me to be VERY cautious about buying anything by Mail Order from anywhere, especially from overseas.
                                                    #544504
                                                    bernard towers
                                                      @bernardtowers37738
                                                      4ba nut spinner. Come on lads you’ve missed a trick, make it from a socket head with a 1/4 socket.
