Apropos of Nothing
Apropos of Nothing
Home Forums The Tea Room Apropos of Nothing
  • #35891
    Enough!
      @enough
      Enough!
        @enough
        Is it just me whom this strikes a chord with ?
        #468665
        Anonymous
          Yep, but designed by Dogbert not Dilbert, who's far too smart to actually finish anything, or stay with a project to the end.
          Cynical wot me?
          #468672
          Howard Lewis
            @howardlewis46836
            They forgot the bit about making the instruction manual unintelligible!
            And if you try to download a copy from t'internet, it will be printed in lilac text on a grey background.
            I kid you not! Speaking from bitter experience
            #468681
            Enough!
              @enough
              Posted by Howard Lewis on 02/05/2020 18:15:11:
              …….printed in lilac text on a grey background.
              Sounds like the early days of microprocessors when purchased source-code (assembler or machine language) was printed like that to avoid photocopying and passing along.
              #468682
              Daniel
                @daniel
                yes
                'bout sums it all up.
                ATB,
                Daniel
                #468917
                JC54
                  @jc54
                  yeslaugh
                  #468982
                  Mick B1
                    @mickb1
                    This is really all about that micro USB connector thing, isn't it? angrywink
                    I always liked this one:-
                    Dilbert's Theorem
                    Dilbert's "Salary Theorem" states that "Engineers and scientists can never earn as much as business executives and sales people."
                    This theorem can now be supported by mathematical proof based on the following two postulates:
                     Postulate 1: Knowledge is Power.
                    Postulate 2: Time is Money.
                    As every scientist knows: Power = Work / Time.
                    Since Knowledge = Power, then Knowledge = Work / Time.
                    Since Time = Money, then Knowledge = Work / Money.
                    Solving for Money, we get Money = Work / Knowledge.
                    Thus, as Knowledge approaches zero, Money approaches infinity, regardless of the amount of work done.
                    Conclusion: The less you know, the more you make.
                    QED!
                    Edited By Mick B1 on 04/05/2020 08:47:51
                    #469086
                    Enough!
                      @enough
                      Posted by Mick B1 on 04/05/2020 08:44:27:
                      Actually, I read it as being mostly about the standard USB connector at the other end of the wire … the one that looks the same on both sides and doesn't go in on the first try; doesn't go in when reversed; then finally goes in when you reverse it again.
                      My favourite Dilbert was this one from about 20 years ago:
                      Edited By Bandersnatch on 04/05/2020 16:27:23
                      #469089
                        Posted by Bandersnatch on 04/05/2020 16:26:34:
                        Actually, I read it as being mostly about the standard USB connector at the other end of the wire … the one that looks the same on both sides […]
                        dont know … don’t those all have the seam in the metal on the bottom ?
                        Mick B1
                          @mickb1
                          Posted by Michael Gilligan on 04/05/2020 16:38:18:
                          …and the bunch of bent arrows on the top. Took me a long while to notice those.
                          #469098
                          Enough!
                            @enough
                            If I knew which side was the bottom* I could answer that wink
                            (or left/right) devil
                            Edited By Bandersnatch on 04/05/2020 17:22:36
                            #469100
                            Enough!
                              @enough
                              Mick, now that I re-read it (several times) I think you're probably right and it is referring to the micro-usb.
