Anyone brave enough ??
Home › Forums › Workshop Techniques › Anyone brave enough ??
  • #341598
    Speedy Builder5
      @speedybuilder5
      Came across this technique – WOW. Go down the page a bit and see the video.
      BobH
      Edited By Speedy Builder5 on 15/02/2018 10:13:11
      #15992
      Speedy Builder5
        @speedybuilder5
        Thermal drill / threading
        #341604
        Clive Foster
          @clivefoster55965
          Saw that technique demonstrated at a FAST (fastener industry) exhibition maybe a quarter of a century ago. Two pillar drills on the table, one for the hole one with a Pollard(?) tapping attachment for the tap. Just like the video. Looked really easy but a bit spendy. Worst point is the rather ragged end to the hole. Might have been a spring loaded blade tool to clean it up.
          Man did say you needed good solid drills with plenty of power. I want to think he had a pair of the then top end Meddings bench type but it was a long time ago. Not Far East Imports thats for sure.
          Clive.
          #341609
          Brian Wood
            @brianwood45127
            Lots of power needed and rather special steels for the penetrators; a heavy test of machine bearings too
            #341610
            Brian G
              @briang
              We looked friction drilling about 25 years back when manufacturing aluminium conservatories. The holes were formed quickly and in a box section the ragged end to the formed boss wasn't important. The downside was time, firstly because our existing multi-spindle air setup couldn't be used so the holes would need to be drilled sequentially and still required tapping. Even before the tooling cost was considered, the additional time cost more than the rivnuts we were currently using.
              #341623
              Brian Wood
                @brianwood45127
                Actually, even more impressive are videos of friction welding using heavy lathes to provide the strength and thrust to force billets of rotating material together until they melt. While molten more thrust pushes the joint together to squeeze out oxide films and leave a very ragged looking outer finish at the joint face.
                That of course is machined off later, but one major benefit of the method is that dissimilar metals can be welded together in one hit without having to make up compatible transition welds.
                Look into work done at the Welding Institute at Cambridge which is where the development work was done
                #341627
                Hopper
                  @hopper
                  Video looks like some of my efforts at centre drilling. laugh
                  #341630
                  Clive Foster
                    @clivefoster55965
                    Brian G
                    I'm impressed that the technique could be considered for aluminium. I'd have expected the high thermal conductivity of aluminium to soften the material around the hole enough for things to distort before a clean extrusion for the tapped hole formed.
                    Clive.
                    #341634
                    Muzzer
                      @muzzer
                      AvE played about with this on Pootube not so long ago. Seemed simple enough although some fruity Canadian language as ever…..
                      Edited By Muzzer on 15/02/2018 14:49:04
                      #341639
                        Dig that krautrock soundtrack!
                        John Reese
                          @johnreese12848
                          What the videos do not show is the very expensive special tool holder that is needed to prevent heat transfer to the spindle bearings.
                        Home › Forums › Workshop Techniques › Topics
