I may have the wiring information wrong. I thought that it went from one light and on to the next etc until the last one but without stripping the lights I am not sure. They weren't fitted by myself I am just going from memory when I lined and insulated the ceiling. The cables are in the roof space and there isn't access now.
As for the temperature, I can go into the workshop and the lights work fine, come out after an hour or so for a brew then when I go back in I can get the problem. It is the complete light fitting ( Both Tubes ) that don't work. Not even a flicker as if they are trying to come on. Flick the switch on and off a few times or even come back later and they work fine.
As I say it can be totally random as to which fitting fails. The supply in the workshop is from the house approximately 25 feet away and supplied through 16mm buried cable to a consumer unit in the workshop. A 10 mm cable then carries on to another outbuilding which has its own lighting and consumer unit and gives no issues at all.
I have noticed that the light fittings give off a steady ticking sound for a while when they are switched on for 5 / 10 mins or so. I wasn't sure if it was them just warming up or something ?????
I have had the wiring checked when the replacement consumer unit and a separate breaker were fitted for the workshop supply as per a previous thread of mine. It is only since the light fittings were swapped for the new ones approx 18 months ago that the issue has arrived.
It is more the nagging inconvenience than anything else. I had always assumed that it was just down to the quality of the light fittings but it happened yesterday so thought I would throw it out there.
I will get somebody in to check them incase there is a fault on them somehow.
Many thanks
