Angled HSS toolholder and tool sharpening angles
Home › Forums › Beginners questions › Angled HSS toolholder and tool sharpening angles
  • #5188
    Frank Small
      @franksmall87776
      #55812
      Frank Small
        @franksmall87776
        Hi Guys
        I have been using carbide tipped tools but in the search of a better finish I am going to  try HSS.
        The HSS holders I have are angeled up about 20 degrees from the horizontal. Is this a standard tool holder?
        Is all the standard published sharpening data re angles etc related  to a horizontal or angeled tool holder.
        Assuming that my tool holders are non standard can someone suggest
        sharpening data and any other ‘work arounds’
        Thank you for your interest
        Frank
        #55830
        John Olsen
          @johnolsen79199
          The angled holders like that are giving you a built in top rake, ideal for steel. This is common on lathe tool holders since it saves grinding a top rake onto the tool, which over a few sharpenings saves you a lot of HSS.. The front still needs clearance, about five degrees typically, and that is relative to the vertical, not to the top face. For brass you don’t really need any top rake.
          regards
          Frank Small
            @franksmall87776
            Hi John,
            Many thanks for clearing up my understanding of sharpening HSS tools
            From what you say I assume the normal published data is for horizontal tool holders and needs adjustment to accomodate the tilt on the tool.
            Frank
            #55841
            Clive Foster
              @clivefoster55965
              Frank
              20 degrees being pretty much the maximum top rake you will ever need you just flatten off as required to get the right one for the job.  It may help to think of the bottom surface of the tool-holder as your zero rake reference.
              One oft overlooked advantage of tool-bit holders is that they make a good “poor boys” Quick Change system substitute as reference to a tool height gauge when changing bits also sets the projection to pretty close limits.  If you fancy trying this best way is to use a slim single slot block type mount, fabricated construction is OK if you don’t fancy heavy milling, and arrange some way of gauging the tool tip height off the top of the mount.  The job in progress tends to get in the way of the usual sort of gauge. Use the bent to the right holder, if you have one, for all normal work as it lets you get closer in to the chuck than the straight one without worrying about clonking the saddle.  Bent to the left for facing work.  Set the business end at 90 degrees to the bed for normal turning and parallel to it for facing.
              All the angles go on the tool so they can easily be replicated using simple templates or a SouthBend style holder if you feel fancy. I feel that a major reason for finish problems encountered by inexperienced workers is the inability to exactly reproduce the tool shape.  Slight shape changes when grinding usually mean that the tool needs to be handled a bit differently for best results.
              #55846
              Dusty
                @dusty
                These tool holders are best used in a ‘boat type’ tool post. This allows the top rake and tool height to be adjusted farly simply by rocking the tool on the ‘boat’ before tightening the clamp bolt. the other adcantage of this type of tool holder is economy of tool steel. generally they use smaller section tool steel and you can use up to the last half inch or 12mm if you prefer.
                #55900
                Frank Small
                  @franksmall87776
                   Hi Guys,
                  Many thanks for your assistance which is very reassuring when information is otherwise  limited.
                  The results I am now achieving are certainly as good as the carbide tips
                  I suspect I could improve that by creating that radius on the tip. I tried using the grinder but it seems too  course.Maybe I will try a stone
                  I will summerise my approach to tool and tool height to date. It is only my approach but  may be helpful to others. I used to set and measure  tool height with a digital vernier but of course it was a hit and miss affair. I was also using carbidre tips. In the search for a
                  better finish I decided to use HSS cutters. I then decided to get serious, measuring tool height accuratly guided by article in MEW
                  1. Turn a shaft to any diameter
                  2. Measure and divide by 2
                  3. Using block and feeler gauge measure height to lower edge of shaft
                  4. Add two results to give tool height.
                  Obtain a block of steel that will stand vertically on saddle and exceeding the tool height by perhaps 10mm
                  Machine a slot to mark the tool height from saddle. This is the tool for setting cutter height.
                  The tools in the angeled HSS holders can now be adjusted in out to set correct tool height as suggested in the forum
                  Carbide holders can  be machined to correct tool height. Something I was reluctant to do until I was sure of the exact  height.
                  Now to gringing the HSS base on my understanding of the help I received on the forum
                  No need to grind a “back rake angle” as this is provided by the tilt of the tool holder. However there is a need to have a side rake angle
                  The profile of the tool as presented to the workpiece should  be the same  as that in the many   well publisied  article.
                  Frank
                  #55907
                  Ian S C
                    @iansc
                    When I first got my lathe setting the tool hight was a bit of a puzzle, so I took my 6″ square, and stood it on the saddle, then I scribed a line across the blade with the hard center in the tail stock, I’v been using that ever since. There are better ways I imagine, but that suits me. Ian S C
                    #55929
                    Billy Mills
                      @billymills
                      Frank,
                      Next time you face off anything in your lathe, the centre pip is more exact than several measurements added because it is the real thing!, when you have exact centre height the top tip of the tool will be right through that pip, slightly too low and you will get a minute pip.
                      The  finish you get is down to the finish of the tool edge, rough grinding -lots of scratches that will be partly reproduced in the job because only the high spots leave a lasting impression.Try stoning the edge and compairing the difference.
                      Alan.
