Aluminium Composite Material
  • #580440
    Alan Wood 4
      @alanwood4
      A contact has asked me to machine some front panels made from 3mm ACM. Has anyone had experience of this material ? (I haven't yet received the samples to play with). My first thought is that the thin top side aluminium skin is likely to tear unless I sandwich a spoil board on top of it.
      #15376
      Alan Wood 4
        @alanwood4
        Best feeds and speeds and spindle RPM
        #580531
        Joseph Noci 1
          @josephnoci1
          Alan,
          What composition is the material in question? There seem to be so many core material types, from resin bonded fibreglass to PTFE, PE, PVC, a variety of foams of different densities, etc…
          I did actually try make some panels from a PVC cored Ali substrate – was not a great success. The PVC was difficult to machine – did not work with high RPMs ( 1200rpm..) and would go gummy and tear the Ali surface. This was quite a few years ago, when I was still in SA, and then managed to find a single flute reverse spiral 4mm carbide mill which worked reasonably – around 800rpm if I remember well and quite aggressive feed rates. The reverse spiral help push everything down, had to use compressed air on the cut line to get swarf out and keep the cutter cool. The Ali still had a rough edge – was not really acceptable to me. I tried some of the HDPE Foam core as well – I never managed with that at all.
          Joe
          #580541
          Circlip
            @circlip
            Isn't a high pressure water system or laser cutter essential for good results for these materials?
            Regards Ian.
            #580563
            Samsaranda
              @samsaranda
              I would think a laser cutter more suited to this but dependent on what the core material is. Dave W
              #580571
              Alan Wood 4
                @alanwood4
                Thanks for the input on this.
                I will see what the sample material performs like and let you know.
                Alan
                #580572
                Adam Mara
                  @adammara
                  At work they use a 1990's Gerber Dimension CNC router with a Perske high speed motor to cut it, using a HS cutter, very little cleaning up required afterwards. Also used with a V cutter through the top layer and core for bending purposes. For general straight cutting they use a DeWalt table saw with a fine TC blade.
                  #580574
                  AJAX
                    @ajax
                    Posted by Samsaranda on 15/01/2022 14:10:04:
                    We aren't allowed to laser cut PVC at work due to the toxic fumes this releases. At home I've CNC machined panels in pvc electrical enclosures with no problems at 8000 RPM
                    #580623
                    old mart
                      @oldmart
                      The variety that I have encountered had the aluminium skins bonded securely to the substrate, it would not have been easy to peel it off.
