Hi Piero,
You asked earlier 'which is better, brass or bronze'?
The answer depends on what you need. Bronze is 'better' as a material than Brass for this application, but Brass has a long history of being used as well. Both alloys are suitable for bearings, bronze being superior.
Bronze will last longer but it's more expensive and harder to machine. A Brass nut won't last as long, but it will be cheaper and easier to make.
So how long does the replacement have to last? Strikes me that the nut won't work hard in a Tool and Cutter Grinder but it will be exposed to grit. Perhaps you should think of the nut as a consumable item. If it lasts 5 years, you've won, if it only lasts 6 months, think again. I'd be inclined to use Brass, perhaps making a spare while I was at it.
There's a collision of ideas in this department:
- Do it properly, fix it once, using the best materials. The problem with this approach is the risk of time and money wasting, with chaps proudly producing gold-plated products too late that can't be sold at a profit.
- Make it 'fit for purpose' using cost-cutting methods in the understanding that all engineering solutions have a limited life. The problem with this approach is the risk of time and money wasting due to the solution being cheap to the point of nastiness, or even a horrible bodge!
Coming to a balance is all part of the fun. In the case of your nut, I suggest:
- Aluminium is cheap and easily machined but almost certainly too soft to last.
- Brass is relatively expensive, very easily machined and 'fit for purpose' for light to moderate use. It's also easy to source.
- Bronze is most expensive, harder to machine and best for moderate to heavy use. An expensive bronze bearing may demand regular maintenance; it cost so much you have to look after it. Normally Bronze would last longer than Brass but the presence of grit in a grinder might remove that advantage unless you keep it clean.
Really useful if you can tell us later what you did and how it worked out.
Edited By SillyOldDuffer on 01/01/2018 10:52:59
