Aluminium as a feed nut
Home Forums General Questions Aluminium as a feed nut
Viewing 25 posts - 1 through 25 (of 32 total)
  • #334494
    Piero Franchi
      @pierofranchi37209
      Just wondering why not use aluminum as a feed nut??
      Was going to try and make my first ever feed nut, its for my Clarkson tool and cutter grinder.
      I will probably mess it up anyway and will take a few attempts at it to get it right.
      but I do know with a lot of cylinder heads (on cars) the cams run straight through the aluminum cast head, no bearing shells,
      thats steel (cast normally) to aluminium so why not my feed nut ????
      Piero Franchi
        @pierofranchi37209
        as title
        #334498
        MW
          @mw27036
          What type of aluminium are we talking about here? Pure Alu is way too soft.
          It normally has to be an alloy or temper to get it hard enough.
          Michael W
          #334500
          John Reese
            @johnreese12848
            I don't think it will last long. Bronze is the traditional material.
            #334503
            Piero Franchi
              @pierofranchi37209
              I dont have any bronze
              #334504
              duncan webster 1
                @duncanwebster1
                Friend of mine used Delrin for the nut on a milling machine feedscrew. Much more heavily loaded than a cutter grinder I think. Just because bronze is traditional doesn't meen other materials won't work.
                Old Triumph motorcycles had the big end running direct on the ally con rod, they lasted for years.
                #334506
                John Rudd
                  @johnrudd16576
                  Cast iron?
                  #334507
                  Piero Franchi
                    @pierofranchi37209
                    My lead screw nut was very very worn and the work would some times be pulled into the grinding wheel.
                    I have now retro fitted a gib locking bolt that will lock the inward moment on the grinder
                    as the table is apart, i quite fancied trying my hand at a new leadscrew nut
                    #334509
                    Mike Poole
                      @mikepoole82104
                      I would not think any aluminium would make a good nut but at the risk of wasting your time making one and having it wear out quickly it could be a good practice for making one in bronze.
                      #334510
                      Andrew Tinsley
                        @andrewtinsley63637
                        The generic 920 lathes seem to all have aluminium nuts on the cross slide. At least the ones I have seen, have them.
                        They do wear out, but it takes a lot longer than you would expect. I have done a replacement on a friends lathe and that was using bronze. If I am going to the trouble of making a well fitting nut, I would prefer that it lasted, so I don't have to do the job twice!
                        Andrew.
                        #334511
                        alan-lloyd
                          @alan-lloyd
                          White metal lined on the Triumph con rods
                          #334514
                          Piero Franchi
                            @pierofranchi37209
                            As I only have aluminium, I think ill try it if only as a test to Polish up on the skills needed to do the job latter on in brass/bronze
                            which of the two would be better. brass or bronze ???
                            #334515
                            Sam Longley 1
                              @samlongley1
                              Oilon plastic or Tufnol whale. Both cheap enough for some experiments & failures during manufacture.
                              #334517
                              Piero Franchi
                                @pierofranchi37209
                                I have much thanks to give some one from this forum (cant find/remember his details) for all my metal. much of which is aluminum.
                                there was this guy from Southampton giving away what he considered scrap
                                to me it was gold!!!!
                                so I have some to play with (aluminum) thanks to this kind gentleman
                                Edited By Piero Franchi on 30/12/2017 19:14:28
                                #334520
                                not done it yet
                                  @notdoneityet
                                  Delrin (acetal) melted and squeezed makes a feed screw nut with virtually no backlash when made (I needed to relieve the thread a little to make it less tight for use). Working as a cross slide feed nut, with better results than the worn out brass item, even though a bit tighter in operation thus far.
                                  Raglan used the die cast lead screw half nuts from the American equivalent. They work OK.
                                  A tool grinder can do without any, or much backlash. I try to never rely on a lead screw nut to prevent backlash. Tightening gibs on anything but the direction of cut makes things much more rigid.
                                  #334522
                                  Bazyle
                                    @bazyle
                                    I think it is worth trying the aluminium as the grinder has a tenth the use of a lathe so it will still last a fair time and you will gain experience.
                                    #334527
                                    Michael Cox 1
                                      @michaelcox1
                                      I have a Delrin nut on my lathe cross-slide. I did the mod some months ago and the backlash is still zero, see:
                                      http://mikesworkshop.weebly.com/tee-slot-cross-slide.html
                                      The part dealing with the Delrin feed nut is at the end of the page.
                                      #334528
                                      Phil Whitley
                                        @philwhitley94135
                                        aluminium bronze, or Duralumin should do the job, and anyway as all have said, it is good practice. the only thing you have to watch for is wear in the middle, or the most used area of the screw thread, then it will be fine at the ends, and slack in the middle. The cross slide thread on my original lathe, a DS&G 13z was beyond the pale, and I couldn't do it, because with it out, I didn't have a lathe! Took it to a local engineering shop, and they cut off the fancy splined end, bored it and fitted a new piece of acme thread into the bore, secured with a roll pin, job done!
                                        #334529
                                        John Haine
                                          @johnhaine32865
                                          The standard feed nut on the ML7 cross-slide uses Mazak I believe! So why not try ali? If/when it wears you can always make another. How big is it? I have some (I think) 25mm bronze bar if you'd like an inch or two after practicing on the ali.
                                          #334532
                                          Nick Hulme
                                            @nickhulme30114
                                            Where Aluminium is used against steel there is often significant wear to the steel.
                                            #334551
                                            Mark Rand
                                              @markrand96270
                                              Aluminium nut with a grinder has the risk of picking up wheel grit and abrading the screw. Bronze is a poor choice unless the screw is hardened and there is copious lubrication (The reason that Bridgeports wreck their feedscrews). Brass will wear quickly.
                                              Acetal is simple to machine and can cope with limited/no lubrication. Cast iron is simple to machine and will wear in preference to the screw. Also more tolerant of limited lubrication.
                                              Edited By Mark Rand on 30/12/2017 23:06:34
                                              #334557
                                              Jeff Dayman
                                                @jeffdayman43397
                                                In the automotive applications the OP mentioned, shafts are run directly in aluminum heads. This practice was also done (and maybe still is) in motorcycles.
                                                The reason it works OK is that a high silicon aluminum die casting alloy, sometimes with some small % of copper added, is used.
                                                I have never found bar stock of this alloy for sale, but if you could find some, or reclaim some from a broken car cylinder head that had direct running shaft in it, it may work.
                                                However given the leadscrew wear you mentioned I think ANY nut material for a new nut may not work as well as is needed. You may be wise to replace the screw also.
                                                #334563
                                                Nick Hulme
                                                  @nickhulme30114
                                                  Posted by Jeff Dayman on 30/12/2017 23:20:40:
                                                  Hydrodynamic bearings are a very different application to a feed screw and nut, suitability of materials in one does not suggest suitability in the other.
                                                  #334569
                                                  Hopper
                                                    @hopper
                                                    Posted by Piero Franchi on 30/12/2017 19:00:28:
                                                    I used brass for the new half nut on my M-Type Drummond Flagellator some years back and it works perfectly. Easier to machine than bronze and less wear on the much more valuable lead screw. That's why some manufacturers such as Myford and South Bend use Mazak for half nuts. (alloy of zinc and aluminium), apart from being cheap, it wears out rather than the leadscrew and can be replaced more cheaply.
                                                    #334583
                                                    Raymond Anderson
                                                      @raymondanderson34407
                                                      Oilon or Nylon 66 would be suitable, although if it were me then I would be using Cast Iron or Phosphor bronze. Each to his own.
