Alloy welding rods on Ebay
Home › Forums › General Questions › Alloy welding rods on Ebay
  • #302301
    vintagengineer
      @vintagengineer
      These are the instructions for using alloy welding rods for sale on ebay!
      Process:Light the torch, (fire shall not be too small, to be able to easily burn pipe next to the heat sink). End of burn
      (preferably vertical burning, the torch can be slightly higher, with blue flames), in the burning process on the electrode
      heating and welding solder powder on powder put it on the stick. With solder powder and try paddling at the required
      welding welding electrode, such as temperature, just like water into welding electrode. If take off the non-stick electrodes
      continue to the end of heating. (Not deliberately used in the welding process the flame burned electrodes, or keep it
      vertical burn status. Uploaded under the electrode will depend on melting temperature. Upon close you will find that the
      electrode is first melted under). Which is why cold electrodes can be causes of welding very thin aluminum parts. Wash
      after welding to weld solder powder, finished.
      #25299
      vintagengineer
        @vintagengineer
        #302305
        peak4
          @peak4
          Google a brilliant at many things, but Google Translate could do with improving a bit.
          It's often said that you should translate into your native language, rather than from it; I think this is a prime example..
          #302308
            Courtesy of google translate:
            Here is the first sentence, translated into traditional Chinese
            Does that help ?
            devil MichaelG.
            #302318
            Jeff Dayman
              @jeffdayman43397
              pls stop using translate
              Edited By Jeff Dayman on 13/06/2017 03:13:32
              #302417
              mark costello 1
                @markcostello1
                2nd one on the right bottom row clearly shows 2 torches playing about on a work piece, can't be much easier to figure out.
                #302434
                Nick Hulme
                  @nickhulme30114
                  Posted by Michael Gilligan on 12/06/2017 23:31:15:
                  Does that help ?
                  devil MichaelG.
                  Funnily enough it does, at least more than anything else so far
                  #302437
                  Ian P
                    @ianp
                    Seems that Google cannot deal with the punctuation marks Michael which makes the translation very confusing.
                    Ian P
                    #302438
                    John Stevenson 1
                      @johnstevenson1
                      Not to mention orphan apostrophes 😀
                      #302442
                        A nice but simpler example of some sort of literal auto-translate being used by (evidently) a non-English speaker are some ABS filament I have here. The label has a couple of Chinese characters and "The colour blue".
                        Edited By Neil Wyatt on 13/06/2017 18:38:43
