Airbrush connections?
Home › Forums › Beginners questions › Airbrush connections?
  • #8795
    choochoo_baloo
      @choochoo_baloo
      #307662
      choochoo_baloo
        @choochoo_baloo
        Evening all.
        Are 'hobby' sized airbush connections standardised (e.g. propane cylinder regulators)?
        I bought a cheap ebay compressor airbrush set (was going to see how far I could go with it), and now wish to upgrade the airbrush – to the linked Harder & Steenbeck – and am hoping that my existing mositure trap will screw into this airbrush.
        https://www.everythingairbrush.com/airbrushes/harder-steenbeck-airbrushes/airbrushes-harder-steenbeck-airbrushes-harder-steenbeck-airbrushes-ultra/harder-steenbeck-ultra-2-in-1-airbrush.html
        Any advice gratefully received.
        #307678
          Most traps and compressors will be 1/4BSP (unless it is a very small compressor) so you will be able to get an adapter from 1/4BSP to H&S and then use an H&S hose
          There is a small chance your e-bay brush may share the same thread as teh H&S but without knowing what it is hard to say.
          #308973
          Henry Artist
            @henryartist43508
            RDG Tools sell a range of airbrush adaptors. **LINK**
            #309109
            I.M. OUTAHERE
              @i-m-outahere
              Just gone through a similar scenario but i needed a new air line .
              Seems most use the same thread but iwata and a few others use a different one 1/8 bsp i think .
              You can get adapters off ebay for most guns although i have a realmcheap gun that uses fittings that are around 5 mm , it is cheap junk but good for priming so i will adapt it to my other fittings .
              Any thoughts on paasche guns ?
              I have a cheap diaphragm compressor and want to add a small air tank to it , possibly from a small fire extinguisher or gas bottle .
              i only use it for my model engines or static models like 1:72 scale models but it seems to work well .
              #309112
              Howard Lewis
                @howardlewis46836
                Whereabouts are you?
                I have an empty small tank, used for filling Helium balloons, (stamped for 130 psi) that you can have.
                I am in East Anglia. (going to Hereford this Sunday to The WaterWorks Museum via A14, M6, M5 if you wanted to meet en route) PM me if any good.
                #309280
                I.M. OUTAHERE
                  @i-m-outahere
                  Hi Howard,
                  Thanks for the offer im in Australia but there maybe someone reading this that can use it .
