Air in steam boiler
Air in steam boiler
Home › Forums › Locomotives › Air in steam boiler
Viewing 25 posts - 1 through 25 (of 28 total)
  • #648635
    Speedy Builder5
      @speedybuilder5
      When steam is raised in any boiler, there is quite a lot of air in the boiler to start with. What happens to this air and does the power of the raised steam increase as the air is driven off?
      Should the first few minutes after raising steam be used to drive off the air ?
      Bob
      #2202
      Speedy Builder5
        @speedybuilder5
        #648645
        Clive Brown 1
          @clivebrown1
          Steam engines usually start off with the cylinder drain-cocks open. I'd think that air from the boiler would be ejected during that time, but I don't think it would be visible separately from the mixture of steam and condensate that emerges.
          #648652
          Martin Kyte
            @martinkyte99762
            The solubility of air in water is around 25×10^-6kg/kg so the boiler is always going to have some air mixed with the steam from the constant replenishment of the water level.
            regards Martin
            #648657
            Andrew Tinsley
              @andrewtinsley63637
              I have seen a loco that was raising steam, shunted up and down a stretch of shed road. The gear was in forward when the loco was shunted backwards and it was in reverse gear when shunted forward. Thus the cylinders were acting as air compressors. The object of the exercise was to get the boiler pressure up as soon as possible, because the loco was needed urgently.
              I was told this by the shed master in charge of the depot. I am not sure if the pumping up of the boiler with air, did any good, however the shed master was adamant that it was a worthwhile exercise. Make what you will of this!
              Andrew.
              #648658
              Mark Rand
                @markrand96270
                in an open system (traction engine, locomotive etc.) it'll go out of the exhaust. In a closed system (power station other systems with condenser under vacuum) the condenser air extraction pumps will remove incondensables, drawing them from the inside of the condenser tube bundles and the deaerator will remove dissolved air from the feedwater. The steam-air ejectors work like locomotive injectors in reverse to draw air out of the turbine and pull a vacuum casings rapidly during startup.
                #648660
                Hopper
                  @hopper
                  Industrial boilers have a vent cock on the top of the drum.When raising steam from cold it is left open until all the air is expelled and steam is coming out. When shutting the boiler down for the weekend etc, a check valve is screwed into the vent cock and the cock opened so that as the boiler cools, air can be sucked in so the boiler does not end up under a partial vacuum, which could strain the tubes etc.
                  #648665
                  John Olsen
                    @johnolsen79199
                    The point of the shunting up and down would be to build up enough pressure to operate the blower. This would increase the draught on the fire, helping to get the temperature up quicker to make actual steam. Forcing the boiler like this is of course not the best for it, but operational emergencies quite often outweigh long term considerations. Ideally you would bring the boiler up to temperature slowly. Some places had provision to connect an air compressor to the boiler for this purpose.
                    duncan webster 1
                      @duncanwebster1
                      Mentioning shutting down at the weekend prompts a slight digression. Where I was drug up in West Yorkshire we got Easter Monday and Tuesday off, not Good Friday. It never occurred to me to question this until I moved away. Suggestion is that mill owners weren't going to shut down Friday, open up Saturday then shut down again, more economical to have 3 days straight. Might be tosh of course. Friend of my dad's was an engine minder, actually quite a skilled job, responsible for keeping the mill engine running and the mill producing. It's all gone now.
                      Edited By duncan webster on 16/06/2023 00:04:55
                      #648672
                      Paul Lousick
                        @paullousick59116
                        Part of the process when raising steam in a boiler is to vent gases/air as the pressure starts to rise.
                        Either by opening a valve at the top of the boiler, opening the drain cocks, open the blower valve or whistle.
                        #648709
                          Posted by Paul Lousick on 16/06/2023 00:55:20:
                          My book doesn't mention that, but it's strong on mechanicals and barely mentions operating. Loads of information on boilers and nothing about how to raise steam.
                          Two mentions of air being allowing in deliberately to avoid damage caused by a vacuum.
                          • When the boiler loses pressure cooling down after work, a valve opens to let air in. This stops the structure from being pressured in reverse, and prevents maintenance accidents. I guess a cold locomotive with a vacuum in the boiler would move unexpectedly if the regulator was opened.
                          • When a locomotive is drifting, a valve opens to prevent a vacuum forming in the cylinder and pipework. If one forms, muck is drawn from the firebox into the works. The book says this is particularly bad for superheaters.
                          Could be wrong, but I don't think a bit of air in a boiler would make any difference to starting and running. If an air filled boiler were heated to 10bar, the steam would be diluted by 10%. However, the air would be at the same temperature and pressure as the steam – much the same energy content -, and the regulator, valves, piston and blast would all still work. (Testing and running model steam engines with compressed air is common. )
                          Once the engine is running the percentage of air would soon drop, and the boiler output would be pure steam.
                          However, air in steam could be bad news chemically. Compressed hot oxygen corrodes metal vigorously and I'd expect it to play havoc with the lubrication too. Short boiler life, and maybe a brief burst of rapid wear on the piston and valves every time the engine is started from cold, forcing more maintenance.
                          Any nastiness would be much worse in full-size than a model – much less air in small boiler than a big one, and models do very little work. A full-size loco would be heated and cooled at least once per day, and they steamed something like a million miles per year. Bad things happen in full-size that don't worry models and vice-versa.
                          noel shelley
                            @noelshelley55608
                            As a boiler cools a vacuum could be 14.7psi ? Would the feed clacks not draw air or water from the injectors Etc ? The valve that opens when drifting is a sniffting valve ? Noel.
                            #648716
                            Redsetter
                              @redsetter
                              Any air contained in the boiler while raising steam will be blown out when the safety valve opens.
                              #648750
                              Andy Stopford
                                @andystopford50521
                                Posted by Redsetter on 16/06/2023 13:18:33:
                                Commercial espresso machines have a pressurestat to cut the electricity or gas supply when the boiler reaches working pressure. When the machine is switched on from cold, the pressure will rise fairly rapidly until the pressure reaches the cut off point, however it won't be at working temperature, it's just the air trapped in the boiler causing the pressure rise, and opening the steam valve will give a brief and disappointing hiss and the pressure gauge will fall back to zero.
                                It's thus necessary to bleed the air off by opening the steam valve a few times to allow the water to heat up to whatever temperature it is that gives the working pressure (1 bar -ish).
                                Strangely, if you leave it for long enough without doing the air bleeding, it will sort itself out and come up to working temperature and pressure. I'm not sure what happens to the air in this case.
                                #648766
                                Nigel Graham 2
                                  @nigelgraham2
                                  The air in a boiler can be a serious consideration on some full-size plant or special equipment, but it does not seem to have been regarded a problem on locomotives and traction-engines. It would be expelled on steam-raising via the blower, cylinder drains and safety-valves; maybe too through auxiliaries like the ejector on first use.
                                  The real problem is that of boiler corrosion by dissolved oxygen in the water, including along the water-line in a boiler laid up part-full.
                                  I have known a miniature side-tank locomotive draw in water as it cooled, and we traced that to the hand-pump in one of the tanks. Not the injector because its water-valve would be closed. Nor would the injector be a way in for air because the overflow valve closes to partial vacuum.
                                  One installation that does need air bleeding from it, is a water main
                                  These, both raw-water ones from the reservoirs to treatment-works, and local distribution lines; are fitted with automatic air-bleed valves at strategic points.
                                  These are very simple and effective: a chamber slightly above the pipe carries a spherical float that drops away from a sealing-ring if air reduces the chamber water-level. The air escapes past it and through a vent, until the float reaches the seal and is held there by what is now just water pressure.
                                  An isolating valve allows the air-valve to be serviced without taking the pipe out of use.
                                  #648767
                                  Hopper
                                    @hopper
                                    Posted by duncan webster on 16/06/2023 00:02:19:
                                    I think you are probably right. It could take many hours, even 12 or more, to gently warm up those big old boilers from cold. Not worth paying the boilermen the extra time to fire it up for one working shift. Also, every time you shut the boiler down and leave it to cool off, all that heat is wasted. And heat is coal. And coal cost money. Not something Yorkshire mill owners were keen on spending unnecessarily!
                                    #648768
                                    Hopper
                                      @hopper
                                      Posted by Speedy Builder5 on 15/06/2023 18:16:17:
                                      … does the power of the raised steam increase as the air is driven off?
                                      Yes it would do. Steam inherently contains more energy than compressed air at the same pressure because the steam contains the latent heat used to convert the water from liquid to gas (steam) form in the boiler. That latent heat is then available to convert into kinetic energy (power) as it is expanded through the engine.
                                      Edited By Hopper on 17/06/2023 00:33:53
                                      #648771
                                      John Olsen
                                        @johnolsen79199
                                        Have to disagree with you there Hopper. The latent heat is usually a total loss. It goes up the chimney on a loco or traction engine, and is lost in the condenser on a condensing engine. Maybe I should say deliberately rejected on the condensing engine, since it is by getting rid of the latent heat that we are able to get a vacuum. So for every pound/kilogram of water we evaporate, there will be a fixed loss.
                                        So it follows that to increase the efficiency we want to reduce the amount of water we need to evaporate. One is to raise the pressure we are working at, which will increase the temperature of the steam and reduce the amount of steam we need to generate the required amount of power. The other way is to superheat the steam, which will reduce the weight of steam needed to fill the cylinder on each stroke, without changing the pressure. So we can get the same amount of work from less total mass of steam. Superheat will also reduce cylinder condensation, often making the engine more lively.
                                        The latent heat can be used for things like process heat in industry, or for district heating schemes. The downside is that the higher the temperature you want the process heat at, the more back pressure you must tolerate on your engine.
                                        Paul Lousick
                                          @paullousick59116
                                          Hi Dave, ( My book doesn't mention that, but it's strong on mechanicals and barely mentions operating. Loads of information on boilers and nothing about how to raise steam).
                                          Which book?
                                          I have a commercial boiler operator's ticket and this is one of the procedures that was taught to us which probably applies to large factory installations with lots of pipe work at higher pressure than used on model engines.
                                          I also drive a full size traction engine, operating at 180 psi and we do purge the boiler of air at start up (only because we were taught that way) and always start the engine, out of gear with the drains open to warm everything before driving. Any air left in the boiler would be purged at this time.
                                          If the reverser is used to slow the engine when going down a big hill, the engine acts like a compressor and pumps air into the boiler, often exceeding the working pressure and blowing-off thru the relief valve with no problem taking-off again when the throttle is opened. (Note: some traction engines do not have brakes and the only way to stop them is to go into reverse)
                                          Edited By Paul Lousick on 17/06/2023 05:25:31
                                          #648773
                                          Hopper
                                            @hopper
                                            Some of the latent heat goes up the stack, or into the condenser water, but not all, I vaguely recall from tech college about 50 years ago, involving things like enthalpy and entropy and adiabatic expansion in the Carnot/Rankine cycle. In a nutshell, I vaguely recall, the latent heat of steam entering the cylinder at say 100PSI is greater than the latent heat of the expanded exhaust steam at say 5PSI. That heat energy has to go somewhere. IE becomes mechanical energy by expanding the steam as the pressure drops as the piston descends the cylinder. This is because as the pressure of the steam in the cylinder drops as the piston descends, the steam is actually superheated, ie the temperature is above the boiling point at that pressure. So that superheat energy is given up as mechanical energy. Adding a condenser lowers the exhaust pressure and temperature, allowing extraction of more latent heat energy before the steam exits the engine/turbine. There is also the factor of partial condensation and then revaporisation of steam as it hits cooler cylinder walls, releasing and reabsorbing latent heat. But my recollection may be completely wrong after 50 years.
                                            Either way, whether it is sensible heat or latent heat, the heat energy contained in steam is greater than in compressed air and will do more work. In practice what you would get in a loco boiler firing up from cold would be an unholy mixture of very wet steam and air and probably would not make much noticeable difference as after the first few strokes of the piston the air would be all or mostly gone and you would be running on steam already.
                                            One thing I do remember from tech college is that the thermodynamics of the deceptively simple steam engine is surprisingly complex, thanks to the thermal properties of water/steam. That is why steam is used rather than compressed or heated air.
                                            Edited By Hopper on 17/06/2023 05:48:17
                                            #648774
                                            Hopper
                                              @hopper
                                              Posted by Paul Lousick on 17/06/2023 05:24:19:
                                              Which book?
                                              Same here. Licensed to run steam boilers on three continents. In industry you always vent the air out of the boiler as it warms up from cold. Air in the steam is corrosive, both in the boiler, the steam pipework, process machinery and the condensate return pipework. So you get rid of it ASAP. A lot of money gets spent on chemicals to help remove air from water and steam throughout the cycle, and on de-aerators to physically remove air from feedwater. So venting the air out of a cold boiler drum as it warms up is important.
                                              Steam locomotives were a relatively primitive piece of equipment, often run on relatively untreated water, without a condenser or condensate return, so they probably did not worry about it quite as much. Just let it go up the stack or out the cylinder drain cocks and called it good.
                                              On model engines it probably matters even less.
                                              #648776
                                              Mark Rand
                                                @markrand96270
                                                Posted by Nigel Graham 2 on 17/06/2023 00:07:01:
                                                To add to Nigels post:- The reason water mains (and coolant pipework in installations such as power stations) have air bleed valves or pilot valves across stop valves is for pipe filling and avoiding water hammer. I was at a station when a 24" auxiliary cooling water line had its stop valve opened during commissioning without the operator opening the 1" pilot valve first. Blew the stop valve off the end of the pipe when the water column hit it…
                                                Edited By Mark Rand on 17/06/2023 07:28:56
                                                #648785
                                                  Which book?
                                                  The book is Poultney, Edgar Cecil. (1edn September 1951) Steam Locomotion. London: Caxton
                                                  Although the book claims to be written from 'the point of view of locomotive engine drivers and firemen, with operating in mind', I disagree. For example, the pros and cons of round and square top fireboxes in both narrow and wide configurations are explained, but not how to actually fire one. More focus on why than how, as when book explains that the design depth of a firebox is limited by the maximum length that can be fired, stated to be about 10' 6", which is why grates may be sloped so that coal falls to the back. (A bit further than the fireman can shovel it!)
                                                  The book tells the fireman why his firebox is arranged just so, but not how to stoke it. I guess the 'how to' part was taught separately. I imagine a callow youth first employed as an engine cleaner being shown how to build and start a fire in the shed so that the engine was ready for the crew when they arrived hours later. Then he might be promoted to learn how to fire a moving shunting engine effectively, gradually gaining the experience needed to stoke main-line goods, passenger and express engines.
                                                  The 1951 date is relevant: written when UK railway steam was at its peak, so good coverage of the end-game. I don't think the book would have been published a couple of years later by which time it was obvious steam was on the way out. Officially so in 1955 and the last British Railways steam locomotive was made in 1960. Although I recommend it wholeheartedly, there was never a second edition. Excellent book for someone like me – comprehensive technical detail, well explained, many drawings, and mostly without the heavy maths a university trained engineer is expected to grip.
                                                  Nigel Graham 2
                                                    @nigelgraham2
                                                    Ah, but five years after your book….
                                                    I cite the official:
                                                    Handbook For Railway Steam Locomotive Enginemen, British Transport Commission, 1957.
                                                    (No author named.)
                                                    This book was reprinted some years ago for the heritage trade, but I can't immediately find my copy to cite it properly and I do not know if it is still in print. TEE Publishing might have copies, as may heritage railway sales-stands.
                                                    It describes the locomotive and its auxiliaries in depth with lots of clear, many coloured, diagrams; explains "The Transformation of Heat Into Power" ( that is the chapter heading) and does give operating instructions and advice.
                                                    I also have a copy of the original, and it bears the rubber-stamped name "M.S. Houghton" and is also stamped "526" and "New England" . I wonder who Mr, Houghton was, and where he was based? Was there a running-shed named New England?
                                                    You are right about how locomotive crews were trained – starting as Cleaner (a horrible job!), moving up through steam-raising to Fireman and eventually Driver with a form of progression to "Top Link" . It's worth reading the autobiographies of former railway and road steam engine-men, to dispel a few illusions perhaps. One I have was by a former goods-locomotive fireman who clearly states he was not reluctant eventually to leave the railways to become an insurance salesman: he may have missed his colleagues but went into clean work in regular day-time hours for better pay!
                                                    The initial stages, in the shed, gave the recruit his general knowledge of what's what on a locomotive, and where he started learning the masses of railway procedures, rules and regulations. (These seem far more, and more complicated, than for driving a car on the roads.) Commonly, once a driver felt the young fireman with whom he'd been teamed or lumbered was sufficiently competent, he would swap places mid-run to give the fireman driving experience; the driver himself doing the firing (while still keeping a look-out for signals and locations).
                                                    #648800
                                                    Hopper
                                                      @hopper
                                                      Yes filthy work. I worked around a couple of coal fired boilers and did not miss the glamour when I left. Wait until you have to climb down into the ash pit to retrieve and repair the chain-grate stoker (a metal chain conveyor belt) that has broken and fallen into the pit. No thanks. Then with the loco guys, there was all that shovelling. They would have been fit.
                                                      Edited By Hopper on 17/06/2023 11:01:10
                                                    Home › Forums › Locomotives › Topics
