The lathe arrived yesterday at about 10.00am, the driver got near to the workshop before the pallet truck grounded – he should have waited for me to lay out the next OSB board and it would have got even closer. Phoned my 2 'recruits' and they arrived half an hour later, I got all my steel bar rollers, large wooden blocks and 'persuader' bar ready for action (had these from a few years ago when I moved my Richmond miller). The lathe was on a wooden base with 3 'skids' which in turn was on a pallet, there was a plywood case covering it and 2 boxes on top held together with plastic strapping.
My neighbour wasn't at work yesterday, so he came to check on things. He then became involved on the operation, good to have his help as he used to work in heavy haulage!
The base of the pallet was in bad condition, so it was decided to get the lathe off and use the rollers under the 'skids'. So strapping cut, boxes removed, plywood case removed, inside the case was the catchplate, faceplate, drip tray, backpanels, footbrake bar and several boxes – all of which were removed to reduce weight.
So we now had the lathe on it's wooden delivery base with skids, using OSB sheets to 'level' the ground it was rollered to the door. At the end, it had to be turned through 90deg to be inline with the door. Now. it was raised about 10" to go over the door threshold using wooden blocks and levers. My neighbour controlling the operation!
It's now in the workshop, with case panels, OSB boards, wooden blocks and rollers abandoned all around – my job for today is to tidy up!
I'll have to move the miller and do some other jobs before it's put on the stand and 'commissioned'. Unfortunately this could take a few weeks because of other commitments. At least the lathe is in he workshop and it didn't rain!
I took a few photos, which I'll post when I get time later.
