Try giving the motor a good shaking. It is possible that the belt tension has slightly twisted the motor on the rods.
(Probably a little squirt of WD40, or a spot of oil on each rod, followed by a five minute wait for it to wick its way in, may help)
If all else fails, a tap with a hide mallet, in the "slacken direction, t MIGHT just shake it loose.
Once loose, it may be worth checking that the locking screws have not raised a burr on the rod, which are causing the jam up
Edited By Howard Lewis on 06/06/2016 09:43:17
