Adjust-true chuck w. 3 adjusting screws
Home › Forums › General Questions › Adjust-true chuck w. 3 adjusting screws
  • #25579
    John Reese
      @johnreese12848
      #323170
      John Reese
        @johnreese12848
        Recently I acquired a Japanese 3 jaw adjust true chuck with 3 screws for adjusting concentricity. I have no difficulty dialing in work on a 4 jaw chuck. The 3 screw arrangement drives me nuts when I try to dial in work. Can anyone recommend a straightforward method for centering work with 3 screws?
        #323175
          Yes, have you got two of the screws at 90-degrees to each other?
          If so, loosen the other screw right off, adjust using the other two, then nip up the 'odd' screw.
          If they are all at 120 degrees to each other, bad luck…
          #323176
            Assuming that they are equispaced [and none of them is spring-loaded] …
            Use the DTI to find the screw that needs to be backed-off most [to move the work towards you]
            Slacken that screw, and tighten the other two equally.
            Rotate the chuck, and repeat the process ad nauseam
            … It's easier to do than to describe.
            Centering Microscope condensers is easier, because one of the three is spring-loaded.
            #323178
            peak4
              @peak4
              Well explained on these to links for the Griptru.
              Bill
              #323179
                Is it this one, John ?
                http://www.yuasa-intl.com/images/products/pdfs/pg86.pdf
                See also: http://www.yuasa-intl.com/products_indv.aspx?pid=36
                Edited By Michael Gilligan on 23/10/2017 23:44:12
                #323183
                John Reese
                  @johnreese12848
                  Niel, It has 3 screws.
                  Michael, It is the 6 1/2 size Yuasa. Thanks for the procedure, except for the ad nauseam part.
                  Peak4, Thank you for the info. My shuck uses setscrews instead of wedges but the procedure should be the same.
                  #323184
                  Hopper
                    @hopper
                    I think I'd be adjusting the three-screw chuck once and leaving set at that, using the four jaw for any precision set ups as it's easier. Cuts out the ad nauseam.
                    #323188
                    John Reese
                      @johnreese12848
                      Posted by Hopper on 24/10/2017 02:07:22:
                      It will not be quite that simple. I have backplates to mount it to either my lathe or my rotary table. Each time I change its location I will have to re-zero it.
                      I found on my other adjustable chucks I had to re-zero them each time I made a significant change in diameter of the part. I assume it is related to inaccuracy in the scroll.
                      #323209
                      IanT
                        @iant
                        I have a (damaged) GripTru lurking somewhere but not been tempted to do anything (like repair it) over the years.
                        To my mind it's a production tool – you set it for a certain diameter work and then just keep repeating with the same size of material. So it's not really designed to be used for constantly changing work diameters, I also have three 4-jaws of various sizes and they get used all the time – much better for one-off work.
                        Just my two 'penneth John but good luck with the "ad nauseum"
                        IanT
                        Edited By IanT on 24/10/2017 09:56:06
                        #323284
                        John Reese
                          @johnreese12848
                          Granted, the GripTru and similar chucks are well suited for production. They are also great general purpose chucks. If you don't mind the runout typical in most 3 jaw chucks, don't adjust them. When you have a critical job that heeds to run true, then you adjust them. That is the way I use mine.
