A quality aluminium alloy (for Myford castings) PRIMER?
Home › Forums › Beginners questions › A quality aluminium alloy (for Myford castings) PRIMER?
  • #341205
    choochoo_baloo
      @choochoo_baloo
      From chatting to an experienced vintage vehicle restorer, I’ve learnt that it’s difficult to get a good primer/key on aluminium alloys.
      As I want to repaint some castings from a Myford ML7, and whilst I know it’s not pure aluminium but some strange aluminium based alloy, please can others recommend primers for painting such alloys – surely there must be a reasonably straightforward process or product to get an excellent key?
      #9089
      choochoo_baloo
        @choochoo_baloo
        #341210
        Chris Trice
          @christrice43267
          Try a supplier to vehicle refinishers. They can supply an acid etch primer that should do the trick.
          #341215
          Hopper
            @hopper
            I used standard spray-can etch primer from the local paint shop on my ML7 with no problems.
            Etch primer is also readily available at local hardware stores, as it is also used for painting galvanized steel etc which is a common domestic building material.
            Edited By Hopper on 13/02/2018 04:44:42
            #341224
            Chris Evans 6
              @chrisevans6
              Another vote for etch primer.
              #341240
              Jonathan Mead
                @jonathanmead91773
                UPol Acid 8 etch primer or Halfords own brand equivalent are good for aluminium and brass. It goes without saying that getting the surface completely clean and degreased is essential for good results.
                #341246
                Robbo
                  @robbo
                  See here **LINK**
                  and here  http://www.halfords.com/motoring/paints-body-repair/primer/u-pol-acid-8-etch-primer
                  Edited By Robbo on 13/02/2018 09:46:30
                  #341264
                  Martin Kyte
                    @martinkyte99762
                    Have you emailed Myfords and asked what they do?
                    regards Martin
                    Edited By Martin Kyte on 13/02/2018 11:01:58
                    #341268
                      Also ask the maker of the finish and U/C you are going to use, not much point on applying a primer if it is not compatible with these.
                      #341273
                      Andrew Tinsley
                        @andrewtinsley63637
                        Paragon paints supply primers and good advice. They also sell Myford grey and I believe green(?). Not the cheapest of paints, but superb quality finishes.
                        Andrew.
