55 Degree dovetail cutter, Where from?
Home Forums General Questions 55 Degree dovetail cutter, Where from?
Viewing 16 posts - 26 through 41 (of 41 total)
  • #164353
    Vic
      @vic
      What about cutting the dovetail to the full width required with a 45° cutter then angling the cutter at 10° and taking a cut on both sides to make it 55°?
      Ian P
        @ianp
        Posted by Vic on 23/09/2014 10:20:27:
        Apart from the fact that its an extra operation that I would need to do twice on each part, the main reason is that I do not want to ever disturb the swivelling head on my mill. I have it absolutely square in both planes by means of trial and error shimming in places not meant to have shims.
        Ian P
        #164358
          Posted by Ian Phillips on 23/09/2014 09:52:57:
          The actual thing I am interfacing to, is a DJI 'Ronin' stabilised camera mount. It is a beautifully made bit of kit and I think incredibly cheap after having seen and examined one.
          Looks very interesting, Ian.
          Edited By Michael Gilligan on 23/09/2014 11:07:06
          #164361
          David Clark 13
            @davidclark13
            You could get a standard 60 degree cutter reground. Should not cost too much or you could regrind it yourself in the lathe.
            Not that difficult.
            #164362
            Vic
              @vic
              Posted by Ian Phillips on 23/09/2014 10:41:33:
              Ian P
              Yes agreed, it is extra work. What mill do you have out of interest?
              #164365
              Ian P
                @ianp
                Posted by David Clark 1 on 23/09/2014 11:24:38:
                Not that difficult.
                Well I'm not keen on grinding in the lathe and it would be unlikely I could grip the cutter shank accurately without having a collet of the correct size.
                I wonder whether it would be better to start with a 45 rather than a 60 degree cutter as the change in angle is less?
                Ian P
                #164369
                Ian S C
                  @iansc
                  Could you set it up and cut the angle in the slot with a slitting saw?
                  Ian S C
                  #164392
                  Ian P
                    @ianp
                    Posted by Ian S C on 23/09/2014 11:56:11:
                    Ian S C
                    An interesting concept, but how would one machine the bottom of the dovetail so that is flat and continuous into the corners? (in other words after the slitting saw had done its job there would be triangle of metal to remove)
                    I want to avoid tilting the mill head
                    Vic, its an Emco Mentor (4 speed head)
                    Ian P
                    #164394
                    Keith Long
                      @keithlong89920
                      Posted by Ian Phillips on 23/09/2014 15:02:58
                      Use a cutter with a shallower  angle than the dovetail side and you should be able to take out the bottom right into the corner
                      Edited By Keith Long on 23/09/2014 15:09:42
                      #164395
                        Can't you just set the work at an angle in the vice, one of the little digital angle boxes will set it to 0.1 degree.
                        If you use a saw for the sides then small flycutter like I showed above will flatten teh bottom & get into the corners.
                        Does it even have to be cut from one piece, you could fix two strips with a 55deg angled edge to main part, thats how I did this one
                        J
                        Edited By JasonB on 23/09/2014 15:14:03
                        #164396
                        Ian P
                          @ianp
                          Posted by Keith Long on 23/09/2014 15:08:24:
                          Well that is basically what I am trying to do! With a cutter of the correct angle its just one operation
                          Ian P
                          #164397
                          Keith Long
                            @keithlong89920
                            Ian – I quite agree – but you don't seem to be able to get a cutter with the correct angle so you're looking for a way round. Now you CAN get a cutter with an angle that will get into the corner IF you cut the sides with a slitting saw. Otherwise it might be time to bite the bullet and order the cutter from the USA if it will do the job, or get a standard cutter modified. For one or two off, the fiddly approach might be acceptable. If you're comtemplating a "production run" then the custom cutter wins hands down in time saving alone.
                            #164398
                            Ian P
                              @ianp
                              Keith
                              As you say its a trade off between getting a cutter made or getting the same result with a series of machining operations. In this case I am looking to make six or ten identical parts so the correct cutter is appealing.
                              Ian P
                              #164405
                              Vic
                                @vic
                                I'd probably bite the bullet and buy a 55° cutter. Only place I've found is this one, £44 for a one inch:
                                http://www.mr-tools.co.uk/catalogue/42.php
                                #164408
                                KWIL
                                  @kwil
                                  Sussextools.co.uk sell 55 degree cutters, I have bought from them. Not a problem.
                                  Edited By KWIL on 23/09/2014 17:04:09
                                  #164420
                                  Ian P
                                    @ianp
                                    Posted by Vic on 23/09/2014 16:40:29:
                                    I did not find that one when I started looking. I would probably not started this thread if I had!
                                    I presume the price shown on their website does not include VAT but I could not find their T&Cs anywhere.
                                    Actually the Sussex tools that Kwil mention have one that is quite a bit cheaper so tomorrow I will contact both potential suppliers and place an order.
                                    Thanks to all for all the suggestions.
                                    Ian P
