32TPI – 0.1330 thread repair
Home › Forums › General Questions › 32TPI – 0.1330 thread repair
  • #308130
    Bob Astill
      @bobastill76884
      I have a carburettor with a stripped bolt hole someone told me the thread was 4-40 UNC so i bought a recoil kit but the tread is wrong the bolt is 3.38mm or 0.1330" and is 32TPI would anyone know what size recoil kit i would need please i have emailed the maker of the carb with no joy.
      Bob
      #25379
      Bob Astill
        @bobastill76884
        #308131
        David Standing 1
          @davidstanding1
          Bob
          32tpi narrows it down. Are you sure the diameter is 0.1330? 6-32 UNC is 0.1380 diameter, and is the only thread I can find that comes near your measurements.
          #308132
          Frances IoM
            @francesiom58905
            just measured a #6-32 and that OD is 3.38mm
            #308133
            Tony Pratt 1
              @tonypratt1
              Maybe the theoretical diameter is .138" but the bolt is bound to be under that, .133" is not a problem. Others I'm sure know where to get the helicoil kit.
              Tony
              #308144
              peak4
                @peak4
                Chronos would be a start **LINK**
                What make of carb is it?
                Bill
                #308146
                David Standing 1
                  @davidstanding1
                  Finding a supplier of the correct helicoil kit won't be an issue, ascertaining for absolute certainty (so Bob doesn't order a second wrong kit) which helicoil kit is required is the first priority.
                  #308152
                  Tony Pratt 1
                    @tonypratt1
                    Posted by David Standing 1 on 21/07/2017 19:50:23:
                    I thought we had already done that? Anyway to be certain buy a 6-32 nut & try the existing bolt in it.
                    Tony
                    #308153
                    David Standing 1
                      @davidstanding1
                      Posted by Tony Pratt 1 on 21/07/2017 20:23:05:
                      Tony
                      No we haven't, because Bob hasn't confirmed he definitely has 6-32 UNC wink 2
                      #308167
                      Windy
                        @windy30762
                        This might not apply but it's not a metric thread is it .
                        What carb is it and year?
                        I did a stripped speedway injector part some years ago it was a metric unit and in this case a 40tpi ME was only slightly smaller than the original metric stripped part.
                        For this I made an insert and lock tightened it.
