Reply To: Helium Ballon
Home Forums The Tea Room Helium Ballon Reply To: Helium Ballon
#609660
    Posted by Hopper on 15/08/2022 08:08:12:
    I suppose modern jets are designed to be somewhat resistant to bird strikes by smaller birds so would survive a balloon. But a balloon might be a hazard for smaller piston engine planes if it got sucked into the intake as happened here CRASH
    The NTSB report for the Hopper's accident can be read here. (LAX94FA047, event occurred 11/15/1993 in Brea, California) It says:
    "The National Transportation Safety Board determines the probable cause(s) of this accident to be:
    THE PILOT'S CHOICE OF AN INADEQUATE CRUISE ALTITUDE OVER ROLLING HILL
    TERRAIN WHICH RESULTED IN AN IN-FLIGHT COLLISION WITH HELIUM BALLOONS
    AND AN IN-FLIGHT LOSS OF CONTROL FOR UNDETERMINED REASONS. A FACTOR IN
    THE ACCIDENT WAS THE PILOT'S INADEQUATE VISUAL OUTLOOK."
    It appears the pilot perhaps with an eyesight problem and definitely flying too low for the terrain flew into a bunch of Helium balloons and power-dived vertically into the ground with both engines running on high-power.
    Possibly something like when my daughter crashed my car (not hers!). Driving along an empty dual carriage-way in twilight at 70mph, something big and black, reared up and ran under the bonnet. She braked and swerved to avoid it and hit a post causing considerable damage, but no injuries. Collecting the wreck I found an empty bin-liner in the debris; my guess is it was inflated by a gust of wind and blown into her side vision causing her to lose control after instinctively jerking the steering and braking hard. As a learner driver I remember being told to run over animals in the road rather than swerve to avoid them. The advice is probably good for the UK where most animals likely to be in the road are small, but may not be smart if the animal is a Moose or Kangaroo!
    Judging by the NTSB reports Helium balloons are completely insignificant compared with small private aircraft. One accident in 1993 compared with about 4 per day in the US. Small private aircraft have a relatively high accident rate mostly because of pilot error, but also poor maintenance. Compared with commercial flight, private pilots take higher risks because they're poorly supported by training, instrumentation, and safety systems. The good news is that accidents are far more likely to kill or injure the pilot and passengers than anyone on the ground.
    The accident reports make interesting reading because they almost always have an accident chain where a series of small non-critical misadventures add up to a catastrophic failure.
    Not suggesting there's a particular problem with light aircraft; motor-bikes, push-bikes, marathon running, horse riding, travelling by road, and living in a city centre are also risky. DIY is quite dangerous too, yet Model Engineering rarely causes accidents. I think it's because lathes, band-saws and mills are fixed and the operator rarely gets too close. Much easier to lose control of a hand power-tool and whack one's fingers with a hammer!
    Edited By SillyOldDuffer on 15/08/2022 10:45:27
    Home Forums The Tea Room Helium Ballon Topics
