What size Lathe to use to make a 1,2 traction engine
Home Forums Beginners questions What size Lathe to use to make a 1,2 traction engine
Viewing 25 posts - 1 through 25 (of 38 total)
  • #351358
    Henry Ruiter
      @henryruiter35703
      What size of a lathe would in need to make a 1″,2″ traction engine.
      Thanks Henry
      #9168
      Henry Ruiter
        @henryruiter35703
        #351361
        Thor 🇳🇴
          @thor
          Hi Henry,
          According to Blackgates their 1" scale Minnie can be machined on a 3 ½ " lathe (i.e. a Myford 7).
          Thor
          #351362
            A lot will depend on the rear wheel construction, some you can use the casting as supplied, some need the casting machined others use a built up rim that does not need to go on the lathe. If you don't need to machine the rims then the final drive gear is the largest part that needs to be turned.
            1" You would need minimum of 5" swing or 6" if the wheels need machining.
            2" Minimum 9" swing or 12" if wheels need machining
            Edited By JasonB on 24/04/2018 07:09:34
            #351363
            Henry Ruiter
              @henryruiter35703
              What is that in MMs or CMs.
              Thanks Henry
              #351365
              Thor 🇳🇴
                @thor
                5" = 127mm
                6" = 152.4mm
                9" = 228.6mm
                12" = 304.8mm
                #351367
                Henry Ruiter
                  @henryruiter35703
                  Thank you Thor.
                  Thanks Henry
                  #351368
                  Henry Ruiter
                    @henryruiter35703
                    What about brands
                    Thanks Henry
                    #351381
                      When you only have 2 things to machine that need a large diameter there are other potential options. You might find a club or evening class with a larger machine, and if you have a milling machine there are more possibilities. Although it seems nice to have a big lathe it ups the cost of all the add-ons quite a lot.
                      Just get a Boxford AUD if you want a used one or check the threads on here about new far eastern machines.
                      #351386
                      David Standing 1
                        @davidstanding1
                        Posted by Henry Ruiter on 24/04/2018 07:12:44:
                        Thanks Henry
                        I'd suggest you brush up on how to convert one to the other and vice versa before you start building your TE wink 2
                        #351388
                        Henry Ruiter
                          @henryruiter35703
                          What do you mean I know the difference between CMs and MMs.
                          Thanks Henry
                          #351389
                          Henry Ruiter
                            @henryruiter35703
                            They don’t teach inches and feet in NZ.
                            Thanks Henry
                            #351395
                              Almost all designs are in imperial, if you can't convert that yourself then try LSM as they have a couple of theirs in metric but don't do small models so you would be looking at a machine that can swing 300mm dia and have a gap that can take 400mm. Also at that size you will need a milling machine..
                              #351400
                              David Standing 1
                                @davidstanding1
                                Posted by Henry Ruiter on 24/04/2018 09:40:11:
                                Thanks Henry
                                I meant the difference between imperial and metric.
                                As Jason says, much model engineering stuff out there is still dimensioned in imperial – apologies from the mother country! blush
                                #351408
                                Henry Ruiter
                                  @henryruiter35703
                                  Sorry it’s just you weren’t clear on that but I could all ways learn it.
                                  Thanks Henry
                                  #351479
                                  Anonymous
                                    This issue is being approached from the wrong direction. For any given scale the size of the engine will vary considerably depending upon it's type. For instance a ploughing engine will be far bigger than a small road engine for the same scale.
                                    So first decide which engine to make, and then look at the largest diameters to be turned, which will determine the size of lathe needed. On my engines the flywheel is rather bigger than the final drive gears, and is the biggest part that needs turning, albeit it can be done in the gap.
                                    #351499
                                    Henry Ruiter
                                      @henryruiter35703
                                      I was looking at the road Locos or the ones that can go on the roads and model I was looking at was the Burrell, Minnie and the Allchin or any model guys could recommen for a beginner.
                                      Thanks Henry
                                      #351501
                                        Posted by Andrew Johnston on 24/04/2018 21:47:40:…
                                        …biggest part that needs turning, albeit it can be done in the gap.
                                        This is an important factor not to be overlooked. A 3.5" lathe can swing much bigger than 7" diameter if it has a gap in the bed, as Myfords and Drummonds do. Just make sure the gap is wide enough to accommodate the job in hand. Myfords will swing up to a 10" diameter faceplate so that is a rough guide.
                                        #351503
                                        Henry Ruiter
                                          @henryruiter35703
                                          I do have a metal ruler that has in inches and CMs so I guess that help a little bit.
                                          Thanks Henry
                                          #351508
                                            Posted by Henry Ruiter on 25/04/2018 01:04:44:
                                            Thanks Henry
                                            If you find doing metric conversion that difficult, have you really looked at the complexity and hundreds, maybe thousands, of hours of work required to build a traction engine? The kind of effort and initiative required is in another league. Perhaps you should look at a simpler project to begin with?
                                            #351509
                                            Thor 🇳🇴
                                              @thor
                                              Hi Henry,
                                              If you struggle with imperial measurements and would prefer to work in the metric system there are drawings of a metric Minnie here.
                                              Thor
                                              #351510
                                              Henry Ruiter
                                                @henryruiter35703
                                                I do get that there’s a lot of work involved in making a traction engine. I would highly dout you could make a traction engine in a week maybe 2-3 year or so yes.
                                                #351512
                                                Bruce Edney
                                                  @bruceedney59949
                                                  Hi Henry
                                                  What part of NZ are you in?
                                                  There are plently of clubs that have members that are willing to help out if needing bigger parts made.
                                                  Cheers
                                                  Bruce (From Wellington)
                                                  #351513
                                                  Henry Ruiter
                                                    @henryruiter35703
                                                    I also build model tanks that have 200-500 plus parts in them witch would take a month or just over and know that’s different scratch building in youself just ETC.
                                                    Thanks Henry
                                                    #351514
                                                    Henry Ruiter
                                                      @henryruiter35703
                                                      Hi Bruce I’m in Christchurch and if have any problems with my maths I can aways ask my old man since he better than I am in it.
                                                      Thanks Henry
