Taper Reamer and Classifieds
Home › Forums › Beginners questions › Taper Reamer and Classifieds
  • #9072
    Philws
      @philws
      #339671
      Philws
        @philws
        I am looking for suggestions on making a taper reamer for woodworking.
        The reamer needs to go up to 35mm with a 6deg taper.
        Any advice on the best way to achieve this would be appreciated.
        I also want to qualify to use the classifieds
        Phil
        #339672
        Emgee
          @emgee
          Hi Phil, what size is the small end, or what length flutes do you need ?
          Emgee
          #339681
            Simple method would be to turn your taper on a piece of silver steel and then mill away half the diameter and then harden & temper. This method is often used for cutting tapers in steam fittings though you will get some tearing in wood depending on grain direction. Could be cleaned up with abrasive paper wrapped around a similar tapered plug.
            #339704
            ega
              @ega
              Is the reamer wanted for making a musical instrument? I am fairly sure that process has been covered in The Woodworker magazine.
              #339951
              John Reese
                @johnreese12848
                A chairmaker's reamer can be pretty simple to make as shown here:
                Simon Collier
                  @simoncollier74340
                  Great photo, Jason.
