Boring in the lathe
Boring in the lathe
Home Forums Beginners questions Boring in the lathe
  • #335625
    Tim Stevens
      @timstevens64731
      When boring using a conventional boring head in the tailstock, I usually position the adjuster dial upwards (for visibility and access), and the tool edge downwards. This seems to work OK. But is there any advantage in using the tool upwards in this set-up, or setting the boring bar with the adjuster horizontal, and the cutter towards, or away from, the adjuster dial?
      It seems to me that the sideways option can result in the forces on the tailstock moving it sideways where there is (inevitably) slack in the guides, whereas the up-&-down forces are better held firm by the tightening of the tailstock.
      But are the other factors at work?
      Regards, Tim
      Tim Stevens
        @timstevens64731
        tailstock boring head – tool position?
        #335628
          Can't say I have ever used the boring head in the tailstock for boring holes. I just use a boring bar in the toolpost which is more rigid and you have power feed for a better finish.
          #335636
          Oldiron
            @oldiron
            I must agree with you JasonB. Its much easier to just dial in (or is that out) a couple more thou on the cross slide than messing with a couple of Allen keys to adjust a tail stock boring attachment.
            regards
            #335642
            Joseph Noci 1
              @josephnoci1
              I think you misunderstand Oldiron…Using a boring HEAD in the tailstock is very convenient. You adjust the cut by means of the micrometer adjustment on the head itself – no need to mess with Allen keys.
              Tim, I use that method often, especially when boring a number of inners to the same size – rough with boring bar close to size, and then finish with the tailstock/boring head – However, not when better than 0.01mm fit is required!
              Also, I set the cutter so that it is horizontal, same as would be with a boring bar in the toolpost. I find that the accuracy is better that way – tailstock is pulled down, which seems less movement on my lathe that sideways. However, good accuracy is hard to achieve as there will always be play in the barrel to body fit.
              Joe
              #335643
                Posted by Joseph Noci 1 on 06/01/2018 19:46:28:
                Joseph, many boring heads have the micrometer screw turned by means of an allen key and the head is also locked and unlocked with an allen key to make these adjustments
                #335645
                Oldiron
                  @oldiron
                  Joseph Noci 1 Both my metric and Imperial boring heads are adjusted using 2 Allen keys. one to adjust and the other to lock. Both have 2 different size keys.
                  regards
                  #335674
                  Joseph Noci 1
                    @josephnoci1
                    Ah, Well…..
                    Joe..
                    #335682
                    nigel jones 5
                      @nigeljones5
                      I recently tried the boring head in tailstock method and found it highly unstable compared to using a normal boring bar in the toolpost – wont try it again.
                      #335688
                      Tim Stevens
                        @timstevens64731
                        My question was not asking about the wonderful advantages of other methods, but your experiences of this particular method in various positions.
                        In case it helps, I have currently no suitable boring bar for the size of hole involved, so it's tailstock (with all its faults, no doubt) or nothing. I've tried nothing and it does not work for me. I won't try it again.
                        cheers, Tim
                        #335695
                          Tim, if the cutter in your boring head fits the hole why can't that be held in the toolpost?
                          #335715
                          Tim Stevens
                            @timstevens64731
                            JasonB, the answer is simple. My boring head, bought for my Myford, is inch, so the cutter is half-inch diameter, and I've pushed as hard as I can, but it won't go into my metric tool holder which is 12mm. I did think about making a half-inch adaptor, but that needs me to bore a hole which is smaller than my boring bar will fit. Deja vu, anyone?
                            The sooner we get out of the EU and our metric tooling is all replaced by the government at EU expense with proper English sizes, the better. That was what the people voted for, after all.
                            Cheers, Tim
                            #335721
                              You don't want to worry if the bar won't fit the toolpost, have you got any G cramps? That 12mm slot in the tool post will make a very good Vee block and fits all international standardswink
                              #335724
                              Tim Stevens
                                @timstevens64731
                                JasonB – the tool holder I have is designed for a boring bar, and has a 12mm hole through it. So, while I agree that I could remove the QCTP support and replace it with my old 4-square tool holder (like yours), and then use engineers clamps to hold the bar against the corners of the slot, I would still face the problem of height, and I was keen to get the job done before it went completely dark.
                                Tim
