127t Gear With ⅞” Shaft and Keyway – Which Lathe?
Home › Forums › Workshop Tools and Tooling › 127t Gear With ⅞” Shaft and Keyway – Which Lathe?
  • #872262
    Captain Barnacles
      @captainbarnacles
      Hello All,
      I was rummaging through my workshop this morning in an effort to “thin out” and came across a 127t change gear. I can’t remember where I got it and I’ve never used it so I thought I’d offer it up for sale here but before I do I wondered if you might help me ifdentify which lathes it might suit please?
      It is approximately 9 ⅛” diameter (233mm), ⅞” shaft diameter, ¼” wide key x ⅛” deep and the gear is ¾” thick. It has 127T cast on the face.
      127t-gear
      Many thanks.
      #872296
      DC31k
        @dc31k
        The most important pointer to which machine it may or may not belong is the DP or module of the gear, which you do not provide.
        A 14DP gear with 127t would be 234mm OD. For more confidence in identifying it, please measure the OD in a way that does not require the ‘approximate’ qualification.
        Colchester are known to have used this DP number.
        If you are passing it on to another who may have use for it, the pressure angle would also need to be known. This can be determined by measuring tooth span or by printing out a paper template and comparing.
        #872307
        Dave Halford
          @davehalford22513
          Wasn’t a 127 wheel part of the Myford metric conversion?
          #872308
          ega
            @ega
            Off the cuff, no!
            #872309
            Clive Brown 1
              @clivebrown1
              I think Myford offered a 127T wheel, but it’s not common. It’s size means it won’t fit in the standard gear-wheel cover and it’s quite pricey. An approximation using smaller wheels was more usual. 63T and 21T spring to mind as drivers I think.
              #872312
                It is too big to be for a Myford.
                Being a 20 DP gear that would be 6.45″ OD, 5/8″ bore and 3/8″ thick, from memory.
                At 9.125″ OD it looks like a 14 DP gear, so looks like for a lathe that uses 14 DP changewheels
                #872316
                noel shelley
                  @noelshelley55608
                  Myford did offer a 127 gear but it was not part of the metric conversion. Noel.
