Mini lathes I need to look into
Home Forums Manual machine tools Mini lathes I need to look into
  • #865664
    mcenhillk
      @mcenhillk
      I was all set to buy a Sherline lathe in a couple of months when we actually move into our house. It was the plan for a last year and on the “I’d like that” list longer. That plan took a turn straight into the hedge with their announcement this week. Their lathes are a bit on the small size but they fit well in a second floor townhouse spare bedroom/office. Now I’m looking for something else. I’m currently looking at the bottom end of the Warco or Chester product lines. Is there something else I should be looking at? I need something I can manhandle up two flights of stairs and can run off standard UK house outlets (240V/13A I think). My projects would be in the clock, pocket watches, and tools for the lathe range.
      #865674
      Andrew Tinsley
        @andrewtinsley63637
        I would include Amadeal in your list of suppliers.
        Andrew.
        #865678
        Peter Cook 6
          @petercook6
          If you were considering a Sherline, how about a Taig from Rotagrip. They are not as “out of the box” ready as a Sherline was, but very capable if dealing with the sort of things you describe. With riser blocks (and a bit of creativity with tool positioning) mine will turn something about 6″ in diameter.
          I bought the version with an ER16 collet headstock and have never regretted it.
          There are currently a couple of standard (3/4 x 16) on E-bay. Or if you have deep pockets consider a Cowells.
          #865679
            … and, if interested in the Taig/Peatol, look here:
            http://www.jeffree.co.uk/modelengineering.html
            Dell
              @dell
              Personally I would take a hard look at the second hand vintage lathes because they were & probably still are much better built, I have restored a good few Pultra lathes 17/50-17/70 & P types & they take some beating, being English accessories are often to be found.
              This is my current Pultra that I use for clock parts the video shows the lack of runout.
              IMG_0592-compressed
              #865689
                Whilst I am impressed by mini lathes, they are pretty heavy to carry upstairs, single handed.
                A friend bought a C1 (no longer imported I think) because he did not fancy just that.
                Dell’s suggestion of a secondhand ML10 or something like it (in good condition)  would be a good alternative. If you are unsure about a used machine, take someone knowledgeable along with you to check it over. A machine in good condition, with a few scars on the paint might be better than a “refurbished” one with shiny new paint.
                Availability of accessories is a point to bear in mind.
                If it is a used machine, check it over carefully. An acquaintance bought what looked to be a really good machine, but when it arrived and he moved the toolpost, it revealed severe damage!
                Good luck finding a suitable machine
                #865690
                  Can’t argue with that, Dell
                  Martin of Wick
                    @martinofwick
                    So you are looking at either the ubiquitous 7xN type lathe and XX 180 type lathes, which weigh in at 60Kg or less to suit your requirement, which is as good as any place to start.
                    Others you can consider which are less commonly available include the SEIG products C0 and C1, I think they are difficult to get in this country now, in anycase the C0 may suit but is rather limited, the C1 much better (I may be biased because I have a C1 and apart from drive belt issues (easily sorted) it has never disappointed and can be manhandled easily.
                    Proxon, are available but rather overpriced (IMHO), and only the larger one has a leadscrew, I think. lathe.
                    Pultra is a plain turning lathe (no leadscrew) OK for clockwork if that is your bag, but it is very hard to find one that does’t need reconditioning at a sensible price. It is primarily a collet lathe and collets or any other parts and accessories are scarcer than hens teeth and priced accordingly.
                    Taig is OK, but again no leadscrew and very much a DIY project to motorise, but there is some back up via rotagrip. People do manage to do heroic stuff with these machines, despite it being a very basic offer.
                    On the ‘any old iron’ market you have Emco Unimats (best bet a Unimat 3 which is the lathe the Seig 0 is based on). Compact 5 is  OK and can probably be lifted, (check on lathes.co). There is another Emco? with a half round bed that come up from time to time – cant recall at present.
                    You could consider a Myford ML10, pretty compact, a little heavier to lift at 65-70 Kg, but I managed to lug one upstairs by removing the motor and any other bits that could be easily refitted (I qualify as yer actual 7 stone weakling and regularly get sand kicked into my face, for the avoidance of those who might think I am one of those individuals who claim to be able to pick up an ML7 in one hand). The advantage of this lathe is there is a thriving secondary market in parts and tooling due to the ubiquity of its big brother, the ML7. These can be had at modest cost and are solid if quirky performers (but I may be biased).
                    Cowells lathes are still manufactured  and come onto the second hand market from time to time, not used one myself but everybody else rants and raves about them (an so they should at the price).
                    Boxford/Emco 8s a bit heavy I think.
                    Wouldn’t bother with any other old Britiron, unless it in immaculate condition and comes fully loaded with chucks, tooling, accessories and sundries etc, otherwise you are in a world of pain and frustration trying to find parts, backplates unless you are prepared to fabricate everything yourself (and usually they are knackered anyway).
                    Probably loads of others, but thats my tuppence worth.
