Is There an Easy Way of Levelling a Rough Bit of Floor?
Home Forums Beginners questions Is There an Easy Way of Levelling a Rough Bit of Floor?
Viewing 25 posts - 1 through 25 (of 34 total)
  • #242146
      Is there an easy way to level a concrete floor under a lathe?
      A few months ago I bought a bigger lathe. My workshop is in a single garage and space is limited. My plan was to put the lathe parallel to a wall where the floor is smooth.
      Disaster – my engine crane has a limited turning circle and there wasn't quite enough leeway to get the lathe in as intended.
      Not a big problem thought I, the lathe can sit at a right angle across the garage. Unfortunately that part of the floor isn't smooth – there are a range of lumps and bumps rising 2 or 3mm above an otherwise flat floor. Before putting the lathe in I reduced the problem somewhat with a cold chisel. It was hard messy work.
      For a while all seemed well. Then I noticed the lathe vibrates enough at 450 rpm to put visible stripes into an otherwise good finish. At other speeds the problem goes away.
      My lathe stand is made of steel and the two pillar sections have thick sheet steel bottoms. These are strong enough to wobble slightly on the ridges in my floor. Putting small wooden wedges under three of the stand corners noticeably reduces the vibration.
      Would sliding a sheet of plywood under the stand help? I'm hoping the plywood might hide the unevenness by allowing the high points to crush into the wood.
      All suggestions gratefully received!
      Thanks, Dave
      #8157
        Richard Marks
          @richardmarks80868
          If you have a 115mm angle grinder Toolstation do a diamond facing disc that will flatten your floor.Diamond Concrete Grinding Disc 100 x 22mm
          #242152
            Dave,
            I don't know if there's anything like it available these days, but: Years ago I had some thick felt that was rolled up in a tin, with some sort of liquid resin.
            This was cut to convenient lengths and placed under the machine stand … After a couple of days, the resin hardened and the machine stand was stable [and slightly vibration isolated].
            Removal was just a matter of slicing into the felt, and then lifting a corner.
            I didn't use it on anything very powerful … Just an engraving machine. But it worked a treat.
            Sorry … Can't remember the name, but someone may recognise it.
            mechman48
              @mechman48
              like you my "workshop" is the single garage; as with all garages there is a tendency for some fall off toward the garage door for drainage. As with you I have ended up with my lathe across the top end of the garage next to the entry door & the mill along the adjoining wall. Before installing the lathe / mill I made up frames for ea. machine & laid a pad for ea.with self levelling compound & followed up with a 1/4" rubber mat under ea. machine stand foot.
              I don't claim total lack of vibration, mainly due to the flimsy fabricated stands provided for ea. machine, but that's another issue so I have added a stiffener between the feet of the lathe stand & stacked a few heavy bits 'n' bobs on to further reduce any vibration, I will later on add another shelf higher up as another stiffener. So far any residual vibration is minimal & doesn't show up on any machining that I do.
              George.
              #242156
              V8Eng
                @v8eng
                I have noticed levelling compounds for sale in Wickes during my recent (frequent) visits, various grades seem to be available. Perhaps that might be worth investigating? No doubt other Stores and Builders Merchants etc stock similar things.
                Edited By V8Eng on 09/06/2016 22:57:05
                Edited By V8Eng on 09/06/2016 22:57:56
                #242157
                  Lift with engine crane, spread weak sloppy sand cement grout under feet about half inch thick, lower lathe, don't touch until set. It won't cure a weak and wobbly stand but will cure the specific problem you have.
                  If the stands are wobbly, and you have definitely decided on the position just build two piers of breeze blocks under the feet instead of the metal stands.
                  #242159
                  DMB
                    @dmb
                    My problem was more one of height with the Myford. I stood it on two brick piers with a strip of roofing felt on the bricks which sticks lathe so it doesn’t move /rock and damping effect.
                    Would my solution suit your problem?
                    Edited By DMB on 09/06/2016 23:37:34
                    #242161
                    Bill Dawes
                      @billdawes
                      Hi Dave, had same problem recently when I bought my new Warco 280V lathe.
                      I bought some self leveling compound from Wickes, stuck down some temporary battens to form a retaining perimeter and poured in compound (it was about 10mm thick) . My fears that it might crumble away proved unfounded (it is not just cement, it has other compounds in it) and it has proved to be a nice flat base.
                      Bill D.
                      #242162
                      Bill Dawes
                        @billdawes
                        Not important but should have said 290V lathe.
                        Bill D
                        #242163
                        John McNamara
                          @johnmcnamara74883
                          Hi Mr Duffer
                          Most builders plant hire companies have concrete wet grinders on hire, I would get one and use it to take off the lumps, there will be a lot lest dust than dry grinding. If there are any holes I would fill them with cement first and let it cure for a week before grinding. Ideally before patching holes they should be painted with concrete bonding agent "Bondcrete" or the like, sometimes patches do not stick well.
                          Many concrete leveling compounds are not designed to be a wearing surface. They have to be covered with another surface, for example tiles or epoxy.
                            Or use some rollers made from 1" pipe to move your lathe to the smooth part of the workshop as you originally intended. I've moved industrial equipment way larger and heavier than your lathe this way. It is a two-man job though, especially on a top-heavy machine like a lathe.
                            #242165
                            Ed Duffner
                              @edduffner79357
                              I'd use a floor Scabbler to remove high spots.
                              Ed.
                              #242167
                              John Reese
                                @johnreese12848
                                You can move a lot with a pry bar and rollers. I have moved 3000 lb. machines this way. Use the bar to raise the machine enough to get the rollers in place.
                                #242168
                                  I don't understand the problem re positioning the lathe where you originally intended. It cannot be so big if you were using an engine crane (assuming here we are talking car engines rather than marine!).
                                  However, wherever installed it should be shimmed to be level and vibration free. Better to bolt the lathe to the floor when shimmed level, unless the base is sufficiently rigid (not the usual case these days?).
                                  #242174
                                  John McNamara
                                    @johnmcnamara74883
                                    A floor scabbler ?
                                    A floor scabbler is a machine that roughens the floor to prepare it for a heavy top coat of usually cement or some other material. Unless the floor is to be re finished in this way it would be very unwise to use one. It is a very rough and rather ugly finish.
                                    A floor grinder on the other hand does what the name implies it grinds away the surface with a grind stone or stones. It leaves a reasonable finish. Your local council will no doubt use them to remove tripping edges on concrete footpaths.
                                    If you do decide to hire a machine make sure you get the right one for the job.
                                    Pero
                                      @pero
                                      One other option, depending on the design of the stand, would be to lift the machine and fit it with adjustable vibration dampening mounts. As per the description, these will make height adjustment very easy and account for any variation in floor level, and also provide some isolation between the machine base and the floor reducing noise and vibration.
                                      For moving machines around in tight spaces (found in all home workshops) I use a goose neck bar rather than a pry bar. It works in small spaces and is good for swivelling machines around. A bit expensive to buy for a one off move but should be available from a local hire shop.
                                      Pero
                                      #242176
                                      frank brown
                                        @frankbrown22225
                                        You can try using pads of roofing felt. If you fancy it, you can get abrasive blocks from builders merchants, about 8" X 1 1/2" X 1 1/2" with two deeply ridges sides, they will grind away concrete. Much less mucky then a disc cutter with a grinder stone. This could be the modern replacement? :- http://www.ebay.co.uk/itm/Silverline-Silicon-Carbide-Rubbing-Block-20-Grit-261034-/121548522005?_trksid=p2141725.m3641.l6368
                                        Frank
                                        #242178
                                        Raymond Anderson
                                          @raymondanderson34407
                                          Dave, The screed that is most often specified by Engineers / Architects for your purpose is Fosroc CEMTOP XD, I use it quite often, it can be applied in a thickness from approx 5 mm to around 40 mm. It has a very high compressive strength and is very abrasion resistant. It is designed to be used when no floor coverings are on top, or it can be covered it makes no difference, It is expensive, but it is designed to do just what you require. If you want to "fit and forget "
                                          I have no knowledge / experience of any of the diy types. ie Wickes, B&Q ect.
                                          Cheers.
                                          #242179
                                          john carruthers
                                            @johncarruthers46255
                                            I've seen the flooring guys level high spots with 'bears', big old grind stones the size of breeze blocks. Attack the lump from all sides with plenty of water to keep the dust down and clear the grindstone pores.
                                            All done with machines now and a smear of compo.
                                            #242180
                                            John McNamara
                                              @johnmcnamara74883
                                              Goose neck bar?
                                              Normal crow bars are fairly cheap, try welding a piece of say 50mm heavy pipe about 150 mm long across the crow bar about 150mm from the end. this gives you a stable nicely rounded levering point.
                                              If you wrap the pipe in duct tape it will give a better grip and protect your floor too.
                                              Boiler Bri
                                                @boilerbri
                                                We level the machine up and run a screed under the feet or pads depending on what the base of your machine is like. They never move and we have had a few machines in place for years Make the screed quite strong 3-1 ratio on silver sand I suppose these days a bit of PVA glue mixed in will be benificial
                                                #242182
                                                Pero
                                                  @pero
                                                  Hi John
                                                  Yes, but not a goose neck wrecking bar. The item in question is about 6 ft (1800 mm) in length and used by waterside workers and those involved in moving heavy machinery, which is how I learned about them. Unfortunately they seem to be known by different names in different jurisdictions.
                                                  On the subject of grinding I have found a piece of concrete breeze block (the heavy variety) plus water is very good for flattening small irregularities in a concrete floor. Dipped in water regularities to remove the cuttings they seem to be very efficient (and cheap).
                                                  Pero
                                                  #242185
                                                  mechman48
                                                    @mechman48
                                                    Michael G…
                                                    Teco pads is the name I recall…
                                                    George.
                                                    #242189
                                                    ken king, King Design
                                                      @kenkingkingdesign
                                                      Surely the most important principle mentioned so far is to get the machine feet/stands lowered onto beds of slightly compliant material of a type which after a time sets hard. During this stage the machine should not be jacked or interefered with in any way. This allows the whole assembly to adopt its natural stress-free stance, in which it is then rigidly supported. Ideally the feet should then be firmly bolted down through their beds, in effect making the floor slab a structural member, and imparting enormous additional rigidity. Any remaining vibration can then only be due to flexing within the upper structure of the machine or tooling, a completely different problem stemming from the basic design, or setup and maintenance issues.
                                                      Ken
