Need help choosing a lathe chuck
Home Forums Workshop Tools and Tooling Need help choosing a lathe chuck
Viewing 25 posts - 1 through 25 (of 38 total)
  • #801714
    th1980
      @th1980
      I have a mini lathe with a 80 mm 3 jaw chuck that came with it. I’m in the process of buying a 80 mm 4 jaw independent chuck but I’m between two choices. I was hoping you could give me some advise about choosing the better one. Or if I should go with some other direction entirely. I have checked so far that both of these should fit my lathe.
      The contenders are:
      https://www.ebay.com/itm/297112062969
      https://www.ebay.com/itm/376237975028
      The latter looks a bit nicer and it has 2 sets of jaws while the first one has reversible jaws that seem a bit clumsy but I’m not an expert about this. All help would be appreciated.
      #801750
      Diogenes
        @diogenes
        Both of those brands are generally okay.
        I think the Sanou looks a bit chunkier and personally I don’t mind reversible jaws – ‘both’ sets are always in the chuck, that way.
        The Soba looks to me like the central bore is smaller? ..does anyone here have one?
        Whereabouts in the world are you?
        #801754
        Tony Pratt 1
          @tonypratt1
          My immediate thought is that the Soba jaws have only one small lug which the screw bears on to move the jaws in and out, I’m thinking that is a weakness.
          Tony
          #801756
          Stuart Smith 5
            @stuartsmith5
            Whichever chuck you buy, make sure it has the correct sized recess and number of fixings to fit your lathe.
            The first one looks like it has 3 fixing bolts and the second has 4.
            If you are in the UK, I would suggest buying from one of the established UK suppliers. If there any problems, you will then be able to return or exchange without any hassle.
            Stuart
            #801759
            Clive Brown 1
              @clivebrown1
              My advice would be to consider going up a size to 100mm. I think this would be well within the limits of your lathe. The extra capacity could be really useful, as this type of chuck can be used for many shapes and sizes of work-piece.
              #801762
              Nicholas Farr
                @nicholasfarr14254
                Tony
                Hi Tony, can’t see any real problem, here’s a photo of my fathers 4 jaw, which is older than I am, and I’ve used this very many times, let alone the number of times my father must have used it. This is a 3 – 1/4″ one.
                20250607_084126
                Regards Nick.
                #801765
                jamesp1
                  @jamesp1
                  Both Sanou and Soba are reasonable quality at a reasonable price. But as with much hobby equipment from over the distant horizon to the east, quality control can be rather erratic. Best to buy from a reputable supplier with a good record for refunding/replacing if you get a substandard item.
                  #801784
                  michael m
                    @michaelm
                    Hi
                    I recently had need of an independant 80mm 4 jaw chuck and bought a similar one to your first example. Mine was not of the same brand but it’s a generic design with different badges, available from many sellers and possibly from the same factory. I have a TOS 80mm three jaw and had expected something of similar scantlings; but no, as you say it’s very clumsy. The jaws are massive with coarse serrations and hardly suitable for the normal size of work for an 80mm chuck and I would also have preferred them to be a better fit on the thread. I wonder if the jaws are actually designed for and used on larger chucks and have been used in this case as a cost reduction exercise? The chuck body seems unnecessarily deep too. Counter intuitively for a four jaw chuck, it has 3 fixing holes
                    In retrospect I wish I’d gone for the Soba which is available from Chronos. It’s of Indian manufacture I believe, rather than Chinese, but I do have a couple of Indian “Zither” chucks which are excellent but seemingly no longer available in the UK.
                    Michael
                    #801788
                    Vic
                      @vic
                      I agree. My lathe came with a 100mm chuck but I managed to get a 125mm four jaw independent for it and it’s been invaluable.
                      The problem is 80mm chucks normally have a 55mm register and 100mm chucks have a 72mm register. The bolt spacing will also be different. I was lucky with my Elliott 125mm chuck, it had a removable back plate I was able to machine to fit my lathe.
                      #801792
                      Vic
                        @vic
                        #801796
                          The Sanou is a standard 4-jaw design, robust, but they take up a fair amount of bed space.
                          The Soba is a low-profile 4-jaw, which creates more bed length, but is less robust.
                          Which is ‘better’ depends on what the lathe is used for.   Unless the extra space is needed, avoid the low profile type.  Apart from being a little on the weak side, having a low-profile won’t help much if the saddle design stops the cutter getting close to the headstock.  If so,  rigidity is lost in the relatively flimsy low-profile chuck AND by having to extend the cutter out to reach the job.   Not the end of the world, but inferior to a sturdy standard 4-jaw that brings the job close to the tool post and minimises cutter overhang.
                          Chuck type sorted, who you buy from matters more than the brand!  Where are you?  The examples are international ebay listings, with the Sanyou priced in USD and the Soba priced in Euros.    A Brit buying a Chinese chuck via the USA risks running into all manner of consumer protection, tax and duty complications.   In this case the Soba is offered by a UK firm (Chronos) but isn’t available in the UK:
                          not
                          Bargains can be had by buying international, but read the small print – it’s risky and potentially expensive.   In the UK, if an import exceeds a certain threshold and is detected, then the recipient pays plus a huge ‘service charge’!   Where the import comes from matters too:  developing countries operate under different rules, so China to UK is cheaper/less hassle than UK to USA.
                          Beware overthinking this stuff.  An ordinary beginner doing ordinary work on an ordinary mini-lathe doesn’t need to worry much. Possible to use a low-profile chuck for years without realising it’s not ideal – the lack of rigidity simply requires the operator to take slightly lighter cuts.   Likewise, it’s possible to manage with a standard chuck when a low-profile would be more convenient.  For what it’s worth, I use a home-made stub mandrel or a faceplate on the rare occasions I need a low profile.
                          So I suggest buying a standard 4-jaw from a local supplier unless there’s a specific need for a low-profile chuck.   Do you have a Dial Indicator?  They’re the easiest way of centring work in a 4-jaw whilst twiddling two chuck keys together.
                          Dave Halford
                            @davehalford22513
                            Ordinarily I would go for the Sanou the finish is so much better  but that one seems rated for non ferrous and plastics and the jaws look too big.
                            Consider your mountings, as bolt spacings above, plus one 80mm will not necessarily fit the register of another’s back plate.
                            #801805
                            michael m
                              @michaelm
                              Using a larger chuck may be relevant up to a point when using the “normal” jaws but when using external jaws there is a risk of the jaw tips colliding before the jaw steps have closed down to the required diameter. This problem is exacerbated when the jaws are unneccesarily large on a small chuck, such as already mentioned. My chuck came from Vic’s recommended seller, no criticism of them, my fault for assuming it would be of “normal” 80mm chuck dimensions. For what it is it represents good value for money.
                              Like much in life it’s “horses for courses”, and lathe chucks have traditionally been manufactured in various sizes for valid reasons.
                              Michael
                              #801809
                              John Haine
                                @johnhaine32865
                                The Samou one looks odd, in some of the pics the outboard ens of the jaws project outside the chuck body and in others not, though they are in the “inner” position.
                                #801813
                                Peter Cook 6
                                  @petercook6
                                  John H makes a good point. The Sanou jaws seem to stick out beyond the body even when closed right down. Will you have enough clearance over the bed to swing the chuck when the jaws are half way open. The Soba looks better in that respect with shorter jaws.
                                  #801898
                                  Clive Foster
                                    @clivefoster55965
                                    Hafta disagree with Dave (SoD) about the desirability of standard 4 jaw chucks compared to light duty (aka low profile) ones.
                                    Most especially when it comes to small ones for model engineering the larger jaws used on standard chucks are far too cumbersome when holding small components. Comparing the advert pictures doesn’t really give a decent comparison of relative sizes. Typically light duty chuck body depth, jaw lengths and jaw widths are around 2/3 rd that of standard 4 jaws.
                                    This picture shows the 8 inch (200 mm) light duty and standard duty four jaws I have for my Smart & Brown 1024. Although over twice the size of the 80 mm ones being discussed the relative proportions between the two types are similar. The loose jaw is one from the standard fit 6 inch (150 mm) three jaw. As can be seen the light duty chuck jaws are of very similar size to the standard fit 3 jaw. Which is generally about right when it comes to holding more precise work.
                                    4 jaw chucks
                                    Standard 4 jaws are sized for getting a firm grip on awkward, often hefty and ill finished components for industrial rates of metal removal, often with interrupted cuts, where you really don’t want the job making a bid for freedom. Not so good at the precision setting thing.
                                    I may have used the standard duty 4 jaw twice in 20 years!
                                    #801902
                                    th1980
                                      @th1980
                                      I didn’t expect so many replies, thanks a lot!
                                      I’ll try to answer some of the questions asked in the previous replies.
                                      I’m located in Finland. My lathe is branded Steeltec XWS003 but it seems to be more commonly known as SIEG C1 in other countries.
                                      I do have some relatives in the UK and they are coming here this summer. Maybe the chuck could fit in their luggage…
                                      The register in my lathe is 55 mm and the fixing hole diameter is 66 mm. There are holes for both options (3 or 4 holes) in the plate.
                                      Maybe a bigger 100 mm chuck could be fitted with an adapter? But there wouldn’t be too much extra room under the plastic guard that is over the chuck. The guard can be removed, of course, but it adds a bit of safety.
                                      There seems to be good and bad sides on both chucks.
                                      Very good point about the protruding jaws of the Sanoy. They would definitely foul the plastic guard, there is less than 20 mm of room (with a 80 mm chuck).
                                      The low profile of the Soba could also cause problems with the guard which is wider that the chuck. Maybe an adapter could help with that?
                                      Perhaps the lesser rigidity of the Soba would not be so much of an issue because my lathe motor is only 150 watts? I’ve gotten used to making very light cuts.
                                      The jaws in the Soba look much better.
                                      The bore in the center is 18 mm in the Soba and 22 mm in the Sanoy. Another point for the Sanoy.
                                      This is getting more and more difficult…
                                      #801905
                                      old mart
                                        @oldmart
                                        I bought an 80mm three jaw scroll and a 100mm four jaw independent rear mount to fit my little 7 X 12 lathe at home. Both of Sanou make. They are both better quality than the pair of 80’s that the lathe came with, but not premium. Unless you have access to a bigger lathe to do some machining on a 100mm chuck, it won’t fit straight onto this type of lathe. There may be adaptors available. I simply remachined the register of the chuck and added front mount holes to suit the lathe spindle.
                                        Both types shown will work well with a small lathe, the Sanou is heavier duty, its reversable jaws are the most common design for all sizes of four jaw independent. The jaws do look oversize,the same size as my 100mm version, looks like they are saving money fitting the same jaws to more than one size of chuck. The other with two sets of jaws has one small advantage on a little lathe, it is shorter in length.
                                        #801909
                                        th1980
                                          @th1980
                                          The 3-jaw chuck that came with the lathe is branded “TIAN PAI”.
                                          The chuck in the link is a self-centering model but it is of very similar build than my 3-jaw. Much nicer jaws.
                                          https://gbr.grandado.com/products/sanou-k12-80-4-jaw-lathe-chuck-self-centering-80mm-with-hardened-steel-for-mini-lathe
                                          #801944
                                          Dave Halford
                                            @davehalford22513
                                            Which it should be for that eye watering money.
                                            #802225
                                            th1980
                                              @th1980
                                              Perhaps the Soba would be better for me then.
                                              #802233
                                              Clive Foster
                                                @clivefoster55965
                                                As ever it’s down to what you intend to hold and selecting the appropriate compromise. Much of the time it won’t matter which you choose as the capabilities overlap.
                                                Bigger jaws for more grip on larger components or smaller jaws for delicacy of holding and being more likely to fit round bits of part machined jobs.
                                                Estimating from casual pictures is never particularily accurate but:-
                                                Sanu jaws appear to be around 15 mm wide and the smallest square they can hold appears to be around 7 mm. Maximum gripping depth appears to be around 15 mm.
                                                Soba jaws appear to be around 10 mm wide and the smallest square they can hold appears to be around 3 to 4 mm. Maximum gripping depth appears to be around 10 mm, likely a bit less.
                                                Best to compare with the jaws on your 3 jaw chuck as you know what that can hold and where, if at all, it falls short of what you’d ideally like.
                                                #802253
                                                peter1972
                                                  @peter1972
                                                  I expect both sets of jaws of the Soba chuck are reversible.
                                                  If you look closely at the photo, the curvature of the steps of the jaws differs. The jaws in the chuck would be suitable for internally holding tube (for example) whereas the other set of jaws would be suitable for externally holding large diameter tube.
                                                  #802262
                                                  Diogenes
                                                    @diogenes
                                                    Yes, it comes with one set of outside jaws and one set of inside jaws..
                                                    #802267
                                                      I’m with Clive and would go for the Soba as the jaws are narrower. I could take a photo just like Clive’s of the supplied 4-jaw with it’s heavy jaws which has not been out of the cabinet for at least 10 years and the slim body Bison that is regularly used as the narrower jaws that fit between flywheel spokes and their ability to close down more win hands down.
                                                      Slim body also works well on a typical mini lathe and other electronically speed controlled lathes where people are tempted to go up in diameter as there is no real increase in mass over a smaller dia chunky chuck so you are not putting extra starting current through the motor and board. They also keep the work closer to the spindle bearings.
                                                      The slim body type have also been the choice of Myford users for years so quite suited to hobby use.
                                                      Also ignore the comment from SOD about not shipping to the UK. Your link is to ebay . com, if you go to ebay . co.uk they will sell to your relatives in the UK or you can buy direct from Chronos and have it delivered to them
