New member looking for help
Home Forums Introduce Yourself – New members start here! New member looking for help
  • #797582
    manfromthemist
      @manfromthemist
      Hi My names Barry from Northumberland in the UK. I’ve recently bought a colchester Student and installed it in my garage hooked upto and inverter,
      I was hoping to get started using it but it has a little issue which I would like to address just to make my life easier when using it,
      hope you guy’s can help
      manfromthemist
        @manfromthemist
        the little issue I’m having is the lever on the front of the head stock that changes the direction of the lead screw will engage a gear when rotated anti clockwise and the lead screw turns feeding th sadle into the chuck and the cross slide from the center out, but When I go to reverse the direction by turning the lever fully clockwise it rotates about half a turn and comes up against something solid but doesn’t engage any gear and does’nt drive the feed system,
        I’ve removed the top of the headstock hoping to see whats in there for something that may be obvious, but I need to drain the oil to see whats under it. Any help or guidance would be very much appreciated.
        #797599
        Harry Wilkes
          @harrywilkes58467
          Welcome to the forum
          H
          #797602
          Grizzly bear
            @grizzlybear
            Hi,
            Got it, crystal ball is now covered up.
            Good luck…………
            #797634
              On Grizzly bear Said:
              Hi,
              Good luck…………
              Ditto!
