My Version of Tapping and Staking Tool
Home › Forums › Workshop Tools and Tooling › My Version of Tapping and Staking Tool
  • #726760
    conrod
      @conrod
      So I had my Fathers face plate from his ML7 sitting around, decided to make use of it.
      Trefolex is a wonderful thing.tap04red
      #726761
        Good idea. I like the adaptation of the standard type tap wrench so it can be changed to suit different sized tap shanks.
        #726776
        conrod
          @conrod
          Yes, I have a “big” and “small” tap wrench, also number stamp adaptor
          #726787
          noel shelley
            @noelshelley55608
            Very neat and so simple ! 10/10 and a gold star. Noel.
            #726789
            jaCK Hobson
              @jackhobson50760
              nice paint job
              #726852
              Chris Crew
                @chriscrew66644
                I made a similar thing out of an old hand-held electric drill stand.
                #726905
                  Like Chris Crew, I made a tapping fixture from the stand mfor an old Consolidated Pneumatic drill.
                  The arm was a piece of box section with two bushes welded in, and then reamed, under ther mill, just by moving the ntablke.
                  The tap is held in a small drill chuck, and the spindle is driven by a short length of 6 x 2 injection piping, as a tommy bar.
                  In this way, the “feel” is still there, but if things get tight, the chuck slips around the tap rather than break the tap.
                  The arm is clamped in position by a bakelite knob on a threaded nrod presing a brass against the pillar.
                  #727095
                  IanT
                    @iant
                    Here’s my version. I take the table off my small drill stand and insert a reamed bush instead.
                    A shaft fitted with an inexpensive ER16 chuck fits into the bush and can slide up & down in it. For small taps, I just hold the chuck. Seems to work very well and is simple to make if you have this kind of drill table. As you will see, I use Trefolex (the magic green stuff) too! A small tin will last a lifetime.
                    IanT
                    IMG_5700
                    #727279
                    Chris Mate
                      @chrismate31303
                      You gave me an idea. Had old restored drillpress gathering dust.
                      -Removed the two nuts holding wheel t top, now you have a floating shaft with chuck.
                      -it works great for tapping the holes in RT disc, slow process however, using what you got. I grab the big wheel itself not the handle for tapping, that gives me a good feel.
                      Note-1:You don’t have to put the nuts back on top, just wind the worm down, connect the ratchet, and it advance the drill down for drilling, easier than I thought, just make sure the its wided back upo for tapping.
                      Note-2:This drillpress base has the nastiest cast Iron I ever drilled, drilled a hole for tap to rest in going down the hole.
