Another Rollo Elf thread
Home Forums Beginners questions Another Rollo Elf thread
  • #147520
    lee hawkins 1
      @leehawkins1
      I was reading a recent thread regarding the Rollo Elf, I didn't want to hijack that thread so I started this one.
      I have got a few questions regarding the (Sturmey Archer Gear hub), I quite like the idea, especially while I have a project running building myself a lathe, I have been taking designed Ideas from lots of different lathes, never came across this one though, do anyone out there have one of these that they use regularly
      The lathe I am building is about twice the size of the Rollo Elf, it will look abit old fashioned in design, but thats no worries for me
      Are these bicycle hubs strong enough?
      As a gearbox for a lathe, do they actually make a difference in the operation of the lathe ?
      Do you actually notice a difference when you change gear ?
      lee
      #7084
      lee hawkins 1
        @leehawkins1
        #147526
        Roderick Jenkins
          @roderickjenkins93242
          Strong enough? Yes. A cyclist can sustain about 1/3 horse power and a big guy stamping up hill puts a considerable torque through the hub.
          As far as the gearbox is concerned there is the possibility of confusion here. The SA hub acts like a gear head lathe and so provides a speed change equIvalent to changing the belt on the pulleys. This gives a slow speed but higher torque or low torque and higher speed, depending on the ratios, which is necessary to cover the machining of differing diameters and materials.
          I hope this is not too simplistic,
          Rod
          #147529
          Ady1
            @ady1
            Theres a video somewhere of the sturmey archer factory before they sold up
            Gigantic machines the size of a bungalow to make tiny supertuff accurate and reliable bike hubs
            #147535
            camper
              @camper
              Have a far eastern 5speed version on a tandem it seems bullet proof, but some of the birmingham ones were a tad iffy. As an aside a hub brake makes decent clutch my 1930 springfield has used a bsa bantam rear for 30 years it is now worth more than the lathe
              #147555
                As a teenage I regularly had the red scar five inches above my ankle to prove the SA hubs didn't always work… it was often down to cable stretch.
                daveb
                  @daveb17630
                  Posted by Neil Wyatt on 20/03/2014 20:24:00:
                  You must have been tall or had a ladies bike, the injuries I suffered due to these infernal devices were not visible to the public but nonetheless extremely painful.
                  Roderick Jenkins
                    With a Rohloff hub you can have 14 speeds and they are supposedly bullet proof: if you've won the lottery!
                    Rod
                    #147561
                    Versaboss
                      @versaboss
                      I seem to remember that somewhere in the past I 'saved' a S-A hub with the idea to use it for a 3-speed drive. After checking the gearing ratios I came to the conclusion that the differences are much too small to be useful. Has the Rollo lathe an additional way to change speeds?
                      Maybe someone can tell the gearing ratios of these hubs?
                      Greetings, HansR.
                      #147564
                      Keith Long
                        @keithlong89920
                        HansR if you go to the S-A website and click on "hubs" in the navigation bar that comes up you'll find the hubs listed and you can click on specs which include the gear ratios. Now those will be for the current product, so no idea how they will relate to "vintage" units, but it will give you some idea of the ratios.
                        Keith
                        Edited By Keith Long on 20/03/2014 22:25:35
                        #147577
                        frank brown
                          @frankbrown22225
                          Years ago i had ST gears on various bikes and seem to remember that they were 1: .8, 1, 1.2 not a very large ratio change for a lathe. Also I was in the habit of bending the spindle, in the end I could change one in an hour, so I do not think there torque transmission would be enough for anything other then a watchmakers lathe.
                          Frank
                          #147578
                          lee hawkins 1
                            @leehawkins1
                            Thanks everyone for posting, a few different opinions
                            So it looks like the Hubs have a questionable strength, but like HansR has said, the ratios are not much good, I wouldn't understand the ratios that would be good for a lathe, on a bike you soon would know soon as you start to peddle
                            On the Rollo elf, would it be down to the pulleys that were fitted, pulley size in conjunction with Hub would surely make a difference
                            I have been searching around for videos of these lathe actually running, cant find anything out there
                            lee
                            Edited By lee hawkins 1 on 21/03/2014 07:00:57
                            #147634
                              Dave, if you suffered such injuries from your pedals slipping…
