Hand cutting frames
Hand cutting frames
Home Forums Beginners questions Hand cutting frames
  • #7061
    nigel jones 5
      @nigeljones5
      #145752
      nigel jones 5
        @nigeljones5
        Did someone once say they enjoyed cutting frames by hand? Those for my 71/4 Invicta are 6mm thick, full of curves and are painfully hard to get right. Nope, no fun whatsoever!
        #145755
          You need to man up a bitsmile p
          #145759
          norman valentine
            @normanvalentine78682
            When I was building my "Dart" I cut the two frames (total thickness 3/8&quot over a period of one week of sawing and filing every evening for about 3 hours. I didn't think that it was too bad. A dreadnought file and a lot of pressure takes metal off very quickly.
            #145761
            nigel jones 5
              @nigeljones5
              Twenty years of seniour management havnt exactly done wonders for my fitness levels! I recon I might pay one of the locals to do the rest face 20
              #145766
              MICHAEL WILLIAMS
                @michaelwilliams41215
                A lot of people including me have used oxyacetylene flame cutter quite successfully on bigger frame plates .
                Not nearly as barbaric as it sounds – with the right flame and a bit of practice you can cut very nearly to the line without doing any damage to finished plates .
                Frames are cut individually of course – not stacked together .
                Michael Williams .
                #145775
                daveb
                  @daveb17630
                  You need another tool……………… a sawing and filing machine, not the little bench one, the floor standing half ton one. Long obsolete now, replaced by EDM. I believe the last ones were Italian made.
                  John Stevenson 1
                    @johnstevenson1
                    Cheque book engineering.
                    Send the DXF file to your local laser cutter and pour a cool one, then collect the plates when sober.
