Hi Bill,
Julian offers good advice.
Re joint gap 2 thou is ok for cadmium bearing but a bit tight for cadmium free silver solder. If using cadmium free open the gaps to 4 thou (0.1mm) – a tight rattle!.
Wire diameters
0.7mm wire is suitable for a joint of length of 4mm and gap 0.1mm or 2mm x 0.15mm gap
1.0mm wire is suitable for a joint of length of 6mm and gap 0.1mm or 3mm x 0.15mm gap
1.5mm wire is suitable for a joint length of 14mm and gap of 0.1mm or 7mm x 0.15mm gap
Make your rings by winding your wire onto a mandrel of the required size to make a spring.
Clamp the spring. Take your propane torch and anneal the spring to remove the tension. Slide the spring off the mandrel – (it won't open up) and cut off the rings with tin snips or similar.
Result rings to size first time.
regards
keith
