Help!
Help!
Home Forums Beginners questions Help!
  • #77317
    Deltic007
      @deltic007
      Hi all,
      Could do with some help with my new machine.
      1. Where do i get a manual for this machine?
      2. Has anyone any idea what BS colour code is closest to Warrco’s machine green?
      3. The machine i have is 3 phase run off a rotary converter,When i use LOW it is OK but when i switch to HIGH it won’t work and the motor just buzzes,Any idea whats up with it?
      Thats all for now and any help would be most appreciated
      Mike Hirst
      #5732
      Deltic007
        @deltic007
        Warco KF-VO-A2F Milling Machine
        #77318
          What machine is it??
          I’ll assume its a Warco of some Sort, you may be able to get one from them but if its one of teh far eastern ones made sold by others you could possibly find a better online manual such as Grizley’s.
          I’ll have a look at my tin of touch up as see if there is anything on it but don’t hold your breath.
          J
          Edit just seen the model in the sub title, this is not the usual Warco code, can you add a picture.
          Edited By JasonB on 05/11/2011 14:36:38
          #77319
          Deltic007
            @deltic007
            Hi mate
            Plate says KF-VO-A2F
            I need to blast and respray the coolant tray and i have access to paint at work so ideally a BS number or some sort of code would be smashing.
            thanks
            #77320
              This looks like it may be a similar mill, manual in pdf format.
              Have not got a full BS chart but if you can convert Dulux Colour Dimension it looks quite close to 4020-G30Y. Nothing on my tin.
              You can but the paint here
              Edited By JasonB on 05/11/2011 14:58:51
              #77321
              Deltic007
                @deltic007
                Pics now in my profile
                #77331
                jason udall
                  @jasonudall57142
                  Re: “buzzing” in HI…in low machine wired in ‘star’ and in high wired in ‘delta’ this means machine uses the motor wiring differently in the two cases…fault might be in switch gear…may be one connection off in the delta mode.
                  #77332
                  Deltic007
                    @deltic007
                    Your right,i stripped the cover off the switch and one of the contacts was broken.Currently trying to source another.
                    #77348
                    Nicholas Farr
                      @nicholasfarr14254
                      Hi Mike, you may wish to find some yellow paint for your tray, below is a picture from one of Warco’s older brochure’s
                      Regards Nick.
                      #77353
                      Springbok
                        @springbok
                        Hi
                        Try
                        look at pics select the one that looks like yours and download a
                        manual not in chingalees.
                        hope this helps
                         Also what part of the world are you in I may be able to point you to the correct
                        source
                        Bob
                        Edited By Springbok on 06/11/2011 03:59:33
                        #77354
                        Terryd
                          @terryd72465
                          Posted by Hirstyboy on 05/11/2011 14:28:15:
                          Hi all,
                          Mike Hirst
                          Hi Mike,
                          I believe that Warco green is in fact ‘Reseda Green’ which is a RAL colour – RAL 6011. There is a RAL colour chart here.
                          If you can take a small painted part such as a cover to a local paint factor, I use a local Johnsons trade centre, they will analyse the paint optically and get the exact colour match. It only need one square inch of flat surface.
                          Best regards
                          Terry
                          #77360
                          Deltic007
                            @deltic007
                            Thanks everyone,I am new to this site but i have to say how impressed i am with the amount of people willing to help……Thanks
                            #77369
                            Bluntdrill
                              @bluntdrill
                              Hi There
                              Your mill is the same as a Myford VMF which I have, it was also sold by Elliot and it seems Warco. I have a manual which I managed to get from Myford, it is not the best in the world but is in decent english. It is 18 pages and has scematic wiring diagram and exploded views of the main componants. I have just noticed that it is listed inside the manual by the same No as yours KF-VO-A2F.
                              I think I can get the manual copied if you are interested send me personal message to arrange details.
                              Regards Jim.
                              Edited By Bluntdrill on 06/11/2011 11:36:09
