new member from Sheffield
Home Forums Introduce Yourself – New members start here! new member from Sheffield
  • #544347
    Dominic Green
      @dominicgreen71596
      Hi everyone
      I have just joined out of curiosity having a number of old modelling projects that my sons and I have on the shelf. I'm keen to learn.
      thanks
      D
      #41065
      Dominic Green
        @dominicgreen71596
        introduction
        #544366
        Brian H
          @brianh50089
          Hello Dominic and welcome. Do you have access to any machinery?
          Brian
          #544378
          Mike Hurley
            @mikehurley60381
            Welcome Dominic. Loads of useful hints, tips & info here, plus quite a few thought provoking discussions and chuckles. enjoy!
            bit more info on what sort of modelling projects you have on the shelf would be interesting.
            All the best Mike
            #544380
            David George 1
              @davidgeorge1
              Hi Dominic welcome to the forum. What sort of projects are you interested in. There are loads of helpful members and you only have to ask.
              David
              #544410
              peak4
                @peak4
                Hello and welcome.
                Was S10-Crookes until I retired, and now moved to Buxton.
                Bill
                #544425
                Harry Wilkes
                  @harrywilkes58467
                  Welcome to the forum
                  H
                  #544562
                  Dominic Green
                    @dominicgreen71596
                    Thanks very much
                    I currently have very little of my own equipment. I can access a lathe but on a somewhat ad hoc basis.
                    as much as anything I am quite interested in using some of the skills and techniques in my working life as a teacher in cinematography and film making.
                    Thanks to David, Harry, Bill and George for your kind welcome.
                    Bill, I imagine that Buxton is a very pleasant spot to retire, a little bit more peaceful than S10, which is looking up a bit these days, we have a couple more cafes now on Crookes main street and a few less empty shop fronts!
                    David, I have a couple of restoration projects, a model aircraft engine of my son’s and a toy sewing machine. I have a particular fascination with automata.
                    I’m anticipating a purchase of a lathe soon which might be something that I can use to make very simple coupling rings and extension tubes for optics as much as for any other purposes!
                    #544583
                    peak4
                      @peak4
                      Posted by Dominic Green on 12/05/2021 09:59:42:
                      I was just opposite The Princess Royal so quite pleasant there; I'm due back soon for a post lockdown haircut from Denise.
                      It might be worth callingthe folk down at McAnearney Machine tools to see if they have anything smaller arriving from a workshop clearance.
                      https://www.pjmachines.com/
                      Bill
                      #544745
                      Dominic Green
                        @dominicgreen71596
                        Hi Bill
                        I'm just down the hill from the Princess Royal myself! Great that you still pop over to Denise's!
                        I'll have a word with McAnearney machine, I drove past them recently and just assumed they dealt with much heavier duty stuff than I could accommodate in the corner of my cellar! Thanks for the tip!
                        Dom
                        #547199
                        Dominic Green
                          @dominicgreen71596
                          As an update, I have found a minor tr1 lathe/mill that wasn't too pricey. I understand that it isn't the most rigid lathe but I hear that it is quite accurate. It looks a bit like an emco compact that I saw (but a lot cheaper). I did consider a unimat 3 but they are quite pricey and I realised that being able to cut threads that are compatible with the filter ring on lenses is going to be very useful.
                          I have it here and I will take a bit of time to look at everything that comes with it, try a tentative first attempt and put some questions on a new thread.
