Making an adjustable vice stop
Home › Forums › The Tea Room › Making an adjustable vice stop
  • #549827
    Steviegtr
      @steviegtr
      I recently fitted a Arc eurotrade precision vice to my milling machine. I decided to have a go at making a adjustable stop for it. I watched many video's on youtube. In the end i made one that i thought was best for my needs. There is also another video of anodising the part & other parts too. If you decide to watch both then i am sorry but it will be 1 1/2 hours of your life you will never get back.
      Unfortunately i do not make drawings for parts i make. I talk them through on the youtube video's. Sort of ad lib. Always been like that. Brain in overdrive. Anyone deciding to watch then enjoy. I will wait to be told to grab my coat.
      Steve.
      Adjustable vice stop ,long video. get a cup of tea.
      Colour anodising alloy parts without battery acid
      #36458
      Steviegtr
        @steviegtr
        To fit the Arc eurotrade precision vice
        #549830
        Jon Lawes
          @jonlawes51698
          You've had some lovely results there.
          #549923
          old mart
            @oldmart
            Well made vise stop, will work very well. You are not the only one who just gets on with making something, exact dimensions are not always needed to get a project underway, all it takes is a bit of imagination. I only use a drawing if the job is for somebody else to their specifications.
            That ARC vise is rather nice looking, how have you found it quality wise?
            Edited By old mart on 15/06/2021 17:48:26
            Edited By old mart on 15/06/2021 17:48:39
            Edited By old mart on 15/06/2021 17:48:58
            #549938
            Steviegtr
              @steviegtr
              Hi old mart.
              The new vise is pretty good. I do not think it has the grip of my Abwood , but for what i do it will suffice. The jaws open up to around 6". Which for a 4" vise is great. The main screw is not acme, but hey for the cost !!!.
              Steve.
              #549939
              old mart
                @oldmart
                The 100mm Bison vises at the museum only open about 70mm, that is why I got one of ARC's 125mm with the swivel, not as nice as that one of yours, but it opens to 150mm.
                #549942
                Steviegtr
                  @steviegtr
                  Yes that was my main reason for purchase. The Abwood only opened 3 1/2".
                  Steve.
                  #549980
                  Andy_G
                    @andy_g
                    On your anodising – I use sodium bisulphate and it works well. There's definitely something wrong with your early attempts (maybe the readout on the PSU was wrong??) I spotted that you were using a steel screw – that's an absolute no-no. I work on 6A per sq ft which means I need ~23Volts at the end of the process (less early on) which is roughly what you were using on the second attempts and it takes ~2 hours to build up a reasonable thickness.(Some examples here: **LINK**&nbsp
                    IME, if the part will take dye after anodising, then the colour should hold after sealing. Your poor result at the end is probably due to a bad electrical connection somewhere – maybe where the hanger rests on the busbar (better to use clamp screws, rather than rely on gravity) or if you're re-using aluminium hangers – they need to be sanded or stripped in caustic between uses (titanium hangers don't.). Mark Preisling did a good video on this.
                    #549987
                    Martin King 2
                      @martinking2
                      Stevie, May I please ask where you got the Bristol Clamping Levers?
                      Cheers, Martin
                      #550000
                      Nick Wheeler
                        @nickwheeler
                        Posted by Martin King 2 on 16/06/2021 08:08:42:
                        Cheers, Martin
                        Axminster tools, Arc Euro Trade, Ebay, they're common parts available all over the place.
                        #550012
                        John Haine
                          @johnhaine32865
                          Stevie, any chance you could post a photo of the finished item please, so we can judge if we want to watch the video?
                          #550014
                          ega
                            @ega
                            Posted by Nicholas Wheeler 1 on 16/06/2021 09:06:21:
                            Cheers, Martin
                            Agreed, but there are Bristol handles and Bristol handles. The best I have found are by Kipp, the least good those made of weak plastic and which cannot be dismantled. EE's Acute kit came with some very pretty small handles that I have not seen elsewhere; perhaps they will be imported under the new trade deal!
                            #550043
                            Steviegtr
                              @steviegtr
                              Posted by John Haine on 16/06/2021 10:11:58:
                              Certainly. Just busy doing some work for a friend , but i will take some later today & post.
                              Steve.
                              #550045
                              Steviegtr
                                @steviegtr
                                Cheers, Martin
                                Ebay Number
                                284045170759
                                Steve.
                                #550047
                                Steviegtr
                                  @steviegtr
                                  Posted by Andy_G on 16/06/2021 01:27:17:
                                  Andy . The 1st attempts were all wrong. I used steel screws & stainless bolts. Now i use just the alloy tig rids wedged into a hole . Yes i was not leaving the parts in the bath for long enough. Thanks for the comments , all taken on board.
                                  Steve.
                                  #550056
                                  Steviegtr
                                    @steviegtr
                                    As asked for . Some pictures of the finished product.
                                    Steve.
                                    #550087
                                    Ian Johnson 1
                                      @ianjohnson1
                                      Thanks for sharing the video Steve, if your results are anything to go by it's given me the urge to try anodising. And I didn't know of that alternative to sulphuric acid.
                                      IanJ
                                      #550091
                                      Steviegtr
                                        @steviegtr
                                        Posted by Ian Johnson 1 on 16/06/2021 19:06:26:
                                        IanJ
                                        Yes it works. I cannot tell you the ratio. I put an amount of S.B in the water & mixed it. It turned out not to be enough. I could not get any current to flow. I mixed some more & it worked fine. My 1st attempts were bad, because i had introduced steel in the bath. Once i had made sure i only had alloy in there it worked. Another thing i found was to give it plenty of time in the bath. Well over an hour at a low current. I did one with the current at about 6 amps on a small part & it just ate it away. Good luck. If i can do it anyone can. The great thing is once you have the materials . Lots of parts can be done for very little outlay.
                                        Steve.
