Most Air compressors Have a air Filter fitted because they need to breath ,A Sealed unit fridge compressor does not breath . I wonder if you continue pumping out air you will eventually create a vacunm in the unit witch will force it to stop , If when running it seems to be strugerling switch of because the motor is getting overloaded
.Good Luck
Brian M
