upshur IC Petrol Engine
Home Forums Help and Assistance! (Offered or Wanted) upshur IC Petrol Engine
  • #303114
    Tom Gullan
      @tomgullan59234
      Hello,
      I have decided that my next project will be to build the Upshur IC Model Pump Engine. My understanding is that I will require a 2:1 ratio gear set. I am not at a standard where I would be able to cut a set of gears for myself so can anyone point me in the direction where I could buy them?
      Also, has anyone any hints or tips for this build?
      Tom
      #33003
      Tom Gullan
        @tomgullan59234
        2:1 Ratio Gear Set
        #303116
        I.M. OUTAHERE
          @i-m-outahere
          Youtube – tinkerjohn .
          He has just started a series on these engines .
          It may help to know where you are in regards to recommending a supplier for the gears .
          Ian.
          #303126
            HPC International are the usual goto for spur gears, Moffett's is another source and if he specifies Boston Gear code numbers then GMB Associates do their geras in the UK.
            #303281
            Tom Gullan
              @tomgullan59234
              Gentlemen,
              Thank you.
              Tom
