Hi All,
Apologies delay i have been away.
Anyway found the name plate…was a bit of a blonde moment !
Motor is, 50Hz single phase, 1/3hp, 2.9 amps, 1450 rpm.
For some reason i cant attach photos, maybe they have to be approved 1st…i have made an album etc but it doesnt recognise it….will try again later.
Anyway the motor is really old, and i think you are correct most likely capacitor has has probably blown. The wiring is a mess throughout the motor and i am probably lucky to be alive !
I see what you mean about 3 phase with VFD….more control of rpm etc and probably more economic to run, but i am not so good with electrics and thought i might just buy a new single phase motor and use the old on off switch, which looks in ok condition. I can get a new single phase approx 1/3 hp (might go a bit higher on power) for approx £100.
Anyway thanks again for the advice.
Kind Regards;
Mark
