3D printers coming of age…?
Home Forums 3D Printers and 3D Printing 3D printers coming of age…?
Viewing 25 posts - 1 through 25 (of 58 total)
  • #134858
    Tony Jeffree
      @tonyjeffree56510
      Take a look at this:
      Admittedly, the 3D printer used in this exercise cost half a million bucks, so it won't be available for hobby use any time soon, but it demonstrates very nicely just how accurate 3D printing can be, and also that the technology is capable of printing objects using more durable materials than plastic.
      Tony
      #31443
      Tony Jeffree
        @tonyjeffree56510
        #134864
        Thor 🇳🇴
          @thor
          Impressive results from that printer. Is this what we will have in our workshop in 10 years?
          Thor
          #134865
          Springbok
            @springbok
            hopefully not makeing guns
            Bob
            #134866
            Speedy Builder5
              @speedybuilder5
              Yes, guns are a bit 'Old Hat' now, but did you see 'Embarasing Bodies' on Tuesday eve.. – The man with half a face. Here was a patient who had half his face eaten away by cancer. Cheek, jawbone pallet etc etc. By use of 3-D printing, surgeons made a replica scull with bits bits missing, then making the missing bits. From these models, it was possible to make a a skeletal jaw 'bone' with teeth, pallet and last of all half a face including a false eye. Not perfect but a hell of a leap for the poor guy.
              #134868
              Springbok
                @springbok
                Wow Speedy
                Yes I have seen the prosthetics, very rarely watch TV But I would like to get into this Technologey but where doese one start..
                Bob
                #134869
                WALLACE
                  @wallace
                  I can’t see all the furore on printing a gun – they’re not exactly difficult to knock up on the average lathe and mill ( I would imagine !).
                  Years ago, my Dad turned up a model cannon at work – couldn’t resist the temptation and charged it up with flash powder and a ball bearing. Which apparently embedded itself into the opposite wall….
                  W.
                  #134876
                  David Jupp
                    @davidjupp51506
                    Mostly it's simply that mentioning guns has proven to be an effective way to generate publicity/hype around 3D printing… much easier to get on the TV than most of the serious and technically interesting things it gets used for.
                    #134880
                    ken king, King Design
                      @kenkingkingdesign
                      If you want a much more interesting and, for us model engineers, meaningful application of a variety of 3D technologies I suggest you google 'building the Miller race car' or very similar title. Sorry I can't provide a direct link at present, but promise that if you're interested in seeing what can be done, you will find the search worthwhile. Plenty of food for thought in this one. If you find it let's have your reactions. This is a fascinating technique, particularly now that very durable metallic prints can be made, plated etc.
                      #134886
                      Springbok
                        @springbok
                        here is link
                        bob
                        #134888
                        Springbok
                          @springbok
                          All I now need is the dosh
                          Bob.
                          #134890
                          Tony Jeffree
                            @tonyjeffree56510
                            Posted by WALLACE on 07/11/2013 20:19:07:
                            I can't see all the furore on printing a gun – they're not exactly difficult to knock up on the average lathe and mill ( I would imagine !).
                            The point isn't that they made a gun – not at all interesting from my point of view to be able to make a gun – but it gives you some clues as to what the technology could be used for. If you can produce a metal gun barrel in a 3D printer and it is strong enough to withstand repeated firing with live rounds, then it isn't exactly a massive leap of the imagination to consider using the same technology to print a ready-bored cylinder block for an IC or steam engine, plus pistons with piston ring grooves, complete camshafts, …. etc. Download the plans, print the parts, job's a good 'un.
                            Yes, as pointed out in the video, there is inevitably going to be a degree of finishing work needed on the printed parts, but even so, the potential uses are very interesting indeed, especially if they could reduce the size of the price tag by a couple of orders of magnitude. Given that you can now buy CNC laser cutters/engravers for an affordable (for the hobby user) price, it shouldn't be much of a stretch to build a laser-based printer for £5k, say that could print metal parts. Maybe not this year, but I would be very surprised if it isn't a reality in the next few years.
                            Tony
                            #134902
                            jason udall
                              @jasonudall57142
                              Maybe 3d printer might be nice project?…
                              Enough mechanical build and electronics to be interesting even if some would turn there noses up at plastic filament build. .
                              #134903
                              David Clark 13
                                @davidclark13
                                Hi There
                                If these designs to print 3D guns are available on the Internet, what is there to stop somone taking the design and machining it manually or CNC milling it from solid metal or am I missing something?
                                regards David
                                #134907
                                Paul Boscott
                                  @paulboscott25817
                                  I am assuming that the idea is that plastic passes through security more easily
                                  #134908
                                  jason udall
                                    @jasonudall57142
                                    Quite
                                    The principles are not even hard for a scratch build..
                                    An automatic might be challenging but a single shot muzzle loaded smooth bore is “just” a closed pipe. . ..
                                    #134909
                                    Speedy Builder5
                                      @speedybuilder5
                                      David, I think the attraction is one machine does all obviating the need for a mill, lathe, drill etc. Also as we seem to be adopting digital design and CNC etc etc, one could pass a file to your local 'foundry' who printed and sintered metal pieces for you. For me, its the sintering process which for MEs could be a real boon if the price were right.
                                      BobH
                                      #134910
                                      jason udall
                                        @jasonudall57142
                                        Plastic/ceramic knives/guns..are available off the shelf…in the case of gunns you might ask why.
                                        #134911
                                        jason udall
                                          @jasonudall57142
                                          There are published designs for plastic steam engine. …
                                          #134914
                                          Ed Duffner
                                            @edduffner79357
                                            I was recently thinking about the possibilities of 3D printing for the scenic railway modeller. All the architecture and line-side accessories and so on. It could also be used for some of the very ornate castings on old steam engines and spoked loco wheels, which could save on owning and powering a small furnace.
                                            #134915
                                            John Stevenson 1
                                              @johnstevenson1
                                              I can see it being just another way forward for the hobby.
                                              OK not at the moment, cost wise but think on a few years.
                                              People with more computer skills than at present, software that's far more advanced than now.
                                              One machine that doesn't need a big draughty shed with probably three times the cost of the machines invested in various tools and accessories to make the machines do what you want [ dividing heads, taps dies , etc, etc. ]
                                              Not saying it will take over traditional model engineering but I can see it making inroads.
                                              Lets face it 10 – 15 years ago if someone told you you could have a CNC router, mill, lathe, laser cutter and 3D printer sat on your bench without having to win a lottery you would have laughed or been burn at the stake as a heretic.
                                              By virtue of the flat earth society dying off any new blood coming into the game has to be younger and by this selection only they will arrive with a different skill set to the departing Jerry Hat Tricks.
                                              For years plans have been sold for making Widget 1, some even sell plans and materials like castings and bar stock.
                                              We are literally only 6 months to 2 years away from someone selling plans and G Code for a CNC to make Widget 1.
                                              #134916
                                              jason udall
                                                @jasonudall57142
                                                John..intesting point..who would own the IP in that case..designer draftman .or g coder..
                                                #134918
                                                Roderick Jenkins
                                                  @roderickjenkins93242
                                                  The designer of course. Possibly a good analogy for printed parts is a casting and I would expect that printed parts may well become available in a similar manner to some of the lost wax castings that are available now. The IP does not belong to the pattern maker or the foundryman.
                                                  There must be enough CNC mills available in the hobby scene to enable someone to start selling G codes for parts but it may be a step too far for the hobbyist model engineer who would cease to have any input apart from as a machine minder. Writing ones own code or developing CAM from your own CAD is a different matter – there is some intellectual input there.
                                                  It will be interesting to see what happens, the future is not very far away.
                                                  cheers,
                                                  Rod
                                                  #134921
                                                  Tony Jeffree
                                                    @tonyjeffree56510
                                                    …but the pattern itself does belong to the pattern maker/foundryman (unless you are explicitly buying that too). The design IP certainly belongs to the designer, but the G-code has IP all of its own, which belongs to the programmer. An analogy – when I write an article for MEW, the IP embodied in the article content/drawings/photos remains mine; however, the IP embodied in how David chooses to lay it out on the page as part of the magazine remains with MEW (or My Hobbystore or whatever this week's company name is…)
                                                    Tony
                                                    Edited By Tony Jeffree on 08/11/2013 15:09:32
                                                    Edited By Tony Jeffree on 08/11/2013 15:09:55
                                                    #134924
                                                      It's interesting to see how the business model is evolving
                                                      One example is Shapeways
