Large Wheel Skeleton Clock Mod’s
Home Forums Work In Progress and completed items Large Wheel Skeleton Clock Mod’s
  • #474162
    David Noble
      @davidnoble71990
      After having John Wilding's clock running for a while now, my wife suggested that the face looked out of proportion! So I copied the excellent Clickspring's bezel that he made for his clock.
      David
      #31299
      David Noble
        @davidnoble71990
        #474172
        lfoggy
          @lfoggy
          That looks great. How did you make it?
          #474241
          David Noble
            @davidnoble71990
            Thank you lfoggy.
            Recessed the back to take the dial, then mounted it horizontally on the dividing head and cut 120deg 'V' s with a boring head. If you like, I can post exact details.
            David
            #474283
            Craig Brown
              @craigbrown60096
              When I saw this in Clicksprings video I was quite frankly blown away. Such an effective design, that just looks fantastic.
              Great job on yours David
              #474292
              Martin Kyte
                @martinkyte99762
                Excellent work, but not sure it's to my taste. But then I'm not a fan of ornate clocks I'm sure you like lots. I'd like to see it on the clock to really tell though.
                regards Martin
                #474335
                lfoggy
                  @lfoggy
                  David, if you could post details that would be great. Will try and find the video you are referring to as well.
                  It looks like you made it out of stainless, is that right? Also can't tell from the picture how big it is.
                  #474360
                  David Noble
                    @davidnoble71990
                    Posted by Craig Brown 2 on 23/05/2020 17:49:34:
                    Thank you Craig, very kind
                    David
                    #474361
                    David Noble
                      @davidnoble71990
                      Posted by Martin Kyte on 23/05/2020 18:20:11:
                      regards Martin
                      Thank you Martin. Vive la differance
                      I have the clock in bits at the moment for a few modifications so I'll try to remember to post a photo' when it's back together.
                      David
                      #474367
                      Martin Kyte
                        @martinkyte99762
                        As you say we are all different. here's a link to the video clip.
                        bezel video
                        regards Martin
                        Edited By Martin Kyte on 23/05/2020 22:15:07
                        #474368
                        David Noble
                          @davidnoble71990
                          Posted by lfoggy on 23/05/2020 20:44:05:
                          Hello Ifoggy, It's 100mm i.d. and 130mm o.d. made from CZ120 engraving brass.
                          I emailed Chris at Clickspring and he very generously sent me this reply:-
                          "Hi David,
                          No problem at all – The cutter is fairly straight forward, just a 120 degree apex swept through an arc of radius 9mm. I indexed approximately 170 to 180, but I don't recall exactly what I used. You will find the DOC by experimentation, as the valleys begin to interset at a nice peak.
                          Best wishes with it!
                          Cheers, Chris. "
                          There were a few problems to overcome such as releasing the bezel from the wax chuck without using heat which would have discoloured the brass. I found that acetone dissolved the superglue quite well.
                          Any questions, please ask.
                          David
                          #474502
                          lfoggy
                            @lfoggy
                            Thanks David, another little project to add to my 'to do' list !
