What’s wrong with T nuts? (compared to T Bolts)
Home Forums Hints And Tips for model engineers What’s wrong with T nuts? (compared to T Bolts)
Viewing 25 posts - 1 through 25 (of 47 total)
  • #148134
    Ian P
      @ianp
      Many times in the past I have seen dire warnings about the danger of T slot damage caused by bolts in the nuts hitting the bottom of the slot and producing enough force to break off the edges of the table slots. This subject has recently emerged again on a Boxford forum I visit and prompted me to seek clarification here.
      What I don't understand is why anyone could think that the force required to break off the lugs is any different in the two situations.
      Various suggestions are repeatably made such as, 'Deform the bottom thread of the nuts' (so bolts cannot project), but I have also seen, 'Never ever use T nuts'!
      In my opinion T nuts are far more useful and versatile than bolts. If somebody told me I could only use bolts I would be seriously hampered.
      Ian P
      #30483
      Ian P
        @ianp
        #148139
        Mike Clarke
          @mikeclarke87958
          Hi.
          I always finger-tighten the stud and then remove the T-nut from the slot and check there is plenty of unused thread. I made my own t-nuts – some suggested damaging the bottom of the threaded hole to automatically prevent the stud being screwed in too far, but I don't think I'd like to rely on that.
          As for the tee-bolt – I guess they avoid the top of the slot being physically jacked up from the base of the slot? And when clamping surfaces to the mill table, it is guaranteed to be simply clamping.
          Cheers,
          Mike.
          #148142
            A screw thread can produce enormouse force so it only takes one half wit in a commercial workshop with a big spanner to misuse it and they can break the machine. Hence the reputation is born.
            #148143
            Les Jones 1
              @lesjones1
              Hi Ian,
              The difference is that sometimes the stud rotates in the T nut when the nut is tightened. This produces a jacking force pushing up on the T slots. With a T bolt the tightening force is just trying to compress the metal above the slot. I sometime saw a screwdriver slot in the end of the stud to hold it when it has a tendency to rotate.
              Les.
              #148144
                Like Ian I can't see the difference in a bolt jacking the nut up from below or overtightening the nut on the top of the clamp, as far as I can see both will exert the same force on the tee nut unless somebody can explain why bottoming the thread puts more upward force on the slot.
                J
                #148146
                richardandtracy
                  @richardandtracy
                  I think it is generally assumed that the work/tooling will be immediately above the T nut/bolt when tightened. That way as the thread is tightened, the thread axial load pushes the work down onto the edges of the T slot and reacts the upward pull of the bolt underneath. This does not happen when the nut is jacked up from the bottom of the slot.
                  The obvious flaw with the 'general assumption' is that you don't always have the bolt underneath some work or tooling that can immediately react this load (as when you are using clamps), so the load is working against the edges of the T slot in exactly the way as happens when you jack up a T nut.
                  So, I agree with Ian in his original post.
                  Richard
                  #148147
                  IanT
                    @iant
                    I can see the concern that with a T-Nut the bolt might be forced through the bottom and jack everything up – whereas a T-Bolt cannot do this. I guess it could happen – although never to me.
                    My understanding has always been that "best practice" is to make sure that the T-Nut/Bolt actually fits the T-Slot well and (where possible) is also supported on the top of the T-Slot. This clearly happens where (for instance) a flat block is bolted directly to the table and the base of it directly covers the top of the slot. However, it is also possible to clamp indirectly by the use of an auxiliary table or (for instance) the rather nice 1-2-3 blocks I got for Christmas (still finding different uses for them JS!). Both of these will help support the top of the T-Slot and have the added benefit of preventing distortion on a slotted lathe cross-slide for instance
                    However, I think the best practical advice is to use as many clamps as possible, don't over-tighten them and rather than go heavy with the clamps – just take a lighter cut. If you are worried enough to want to really tighten up your T-bolts/nuts – then perhaps it's time to stop and re-think your clamping arrangements.
                    IanT
                    #148149
                    Oompa Lumpa
                      @oompalumpa34302
                      Just proves the old adage, common sense isn't.
                      I put people into two classes (shallow I know) :- Mechanically Sympathetic people and everybody else. I firmly believe that mechanically sympathetic people have a far higher understanding of the world around them.
                      Not on topic and Philosophical for nine thirty in the morning, but hey, I feel philosophical today.
                      graham.
                      #148150
                      Phil H 1
                        @philh1
                        Jason/ Ian,
                        I think I can see part of the concern.
                        I can imagine a 'bottomed' stud being tightened into the table causing stress round the slot whilst for example, the component is still loose because of a sticking or bottomed top nut (perhaps the top nut has been run down the thread onto the plain part of the stud?). The temptation – if you are half asleep – might be to keep turning the spanner without clamping the component putting more and more stress on the slot.
                        I think I need a picture but that might be the concern.
                        Phil H
                        #148151
                        Mike Clarke
                          @mikeclarke87958
                          Posted by JasonB on 27/03/2014 08:46:11:
                          J
                          If you put a bolt in a tee nut in a slot and tighten it – as an example – surely that is trying to force the nut through the top of the table. That's what I imagine the concern to be anyway (when something is in contact with the table directly above, i.e. vice, rotary table, fixture etc).
                          Edited By Mike Clarke on 27/03/2014 09:36:44
                          #148152
                          Nicholas Farr
                            @nicholasfarr14254
                            Hi, a couple of things to consider are that while you are tightening the studs in a T nut, it can turn and bottom out in the T slot and you will have the clamping force of the work you are holding plus the jacking force of the stud bottoming out, so you can have two independant forces being applied to the same area of the slot.
                            The other thing about tightening bolts or studs is that they in them selves have and elastic range in thier use and of course if you get heavy handed with the spanner damage can occur. When a stud is in a jacking situation, the stud does not compress to the same extent as a stud will stretch and therefore the force can be much greater.
                            The same thing can happen when studs are allowed the bottom out into a blind threaded hole although the tightening torque may not have been reached.
                            Regards Nick.
                            Edited By Nicholas Farr on 27/03/2014 09:42:13
                            #148153
                            Russ B
                              @russb
                              Surely this is a lesson in good practice – I'd never jack my T nut up using the bottom of the slot, and my T nuts, both made and bought all have 2-3mm clearance.
                              I screw the stud in, then I lift up and down to make sure I still have 2-3 movement, then I crack on with the clamping.
                              If the Nut is tight on the stud so much it can't be held by hand, then stud or the nut's threads are damaged, bent or stretched etc. etc. and go straight in the scrap bin to be reborn another day.
                              – I would expect the whole clamp assembly to be tightened finger tight, then receive a 1/2 to 1 turn to tighten, so even if it did tighten completely in the T nut, it still wouldn't stick out more than the 2-3mm gap under the T nut.
                              #148155
                              dave greenham
                                @davegreenham19379
                                Surely the simple answer is to make your own studs
                                but only thread the bottom so far ensuring that it doesn't protrude
                                through the bottom. The bare part of the stud stops it going through
                                so the problem doesn't arise .
                                dave
                                #148156
                                Russell Eberhardt
                                  @russelleberhardt48058
                                  I just make my T-nuts with a thread going about 2/3 of the way through. Having said that I have never had any problems with commercial ones but then I am no gorrilla and I use short spannerssmiley
                                  Russell.
                                  #148157
                                    I believe that when Whitworth defined his standard threads he also defined standard ie maximum lengths for the spanners to reduce the ability of monkeys to overtighten them.
                                    I have some T bolts in my scrap bin, half inch I think, that have the treads distorted to sawtooth shape at the point where the nut was.
                                    #148158
                                    jason udall
                                      @jasonudall57142
                                      Might I suggest the difference is this..
                                      Given that the protrusion of stud is short relative to the length above the table and that the “tensile modulus” of said stud is less than the compressive “modulas”..
                                      It means the jack situation is much stronger than the pull …consequently there is more force available ( before yield in the stud) when your tame gorilla swings on the spanner.
                                      In production ws I see torque wrenches uses specifically for tightening ..
                                      #148160
                                      jason udall
                                        @jasonudall57142
                                        What I am trying to say is..the give is the stud in tension is much larger than in compression. .thus “feel” is much less forgiving in the jack situation than the pull
                                        #148161
                                        Rick Kirkland 1
                                          @rickkirkland1
                                          Oompa lumpa! Right on! Yeahhh!
                                          Rick
                                          #148162
                                          Gordon W
                                            @gordonw
                                            Two things to consider- Stud could jack up the nut and break the table slot, If a bolt is used in T nut there is no way to tell if the work is clamped or just bottoming out. This was hammered into me when a youth. Do not use bolts.
                                            #148163
                                            richardandtracy
                                              @richardandtracy
                                              Posted by jason udall on 27/03/2014 09:57:49:
                                              Given that the protrusion of stud is short relative to the length above the table and that the "tensile modulus" of said stud is less than the compressive "modulas"..
                                              I remain unconvinced by this. If it were the case, surely tensile & compressive moduli would be quoted for steels. They are not, but in many composite materials, tensile & compressive moduli (as well as strengths) are quoted because the materials have radically different values. In tests on my degree course at university we established that the E for the steels we were given (EN24 & EN16) was the same in compression as it was in tension to better than the experimental error of 1%. Quite why we needed to prove this at the time, I have no idea, and this is the first time since (30 odd years) I've ever had the chance to refer to it.
                                              Richard.
                                              #148165
                                              Russ B
                                                @russb
                                                Posted by Rick Kirkland 1 on 27/03/2014 10:24:52:
                                                Rick
                                                Yeah, I like this too
                                                I think ultimately, a T bolt, is a fool proof T nut, and a T nut with a damaged or blind thread is essensially a T bolt for all intents and purposes.
                                                ……….. and an uncouth mechanically unsympathetic gorilla – is an uncouth mechanically unsympathetic gorilla cheeky
                                                Edited By Russ B on 27/03/2014 10:43:08
                                                #148169
                                                Ian P
                                                  @ianp
                                                  I seemed to have touched a raw nerve here! but it does seem that quite a few people have an abhorrence or aversion to T nuts. Thanks to those that have replied (and to MW for the PM)
                                                  My observations of the usage of T slots is that the force to break of the ears of the slot are the same where ever it comes from. Surely this can only be from a careless operator?
                                                  If something is clamped down to the table trapping the ears of the slot then they are not going to break off, but equally that particular fixing is mainly going to be used for lateral location so its no good for say, holding a vice down (the type with grooves on each side for clamping plates)
                                                  If I use a bolt or a length of studding in a T nut its very easily apparent when the thread bottoms. Even if a stud bottoms the actions of tightening the nut actually reduces pressure on the bottom of the slot.
                                                  I'm going to carry on using T nuts (well, and my two T bolts as well)
                                                  Ian P
                                                  #148170
                                                  jason udall
                                                    @jasonudall57142
                                                    Richardandtracy…
                                                    I too have not seen seperate moduli listed.
                                                    But the “geometry” remains the ctitical difference. .shorter element below thus less “squishy” than the say ten times longer element in tension “hooke law”..
                                                    #148171
                                                    richardandtracy
                                                      @richardandtracy
                                                      Guess I was nit-picking. You are right, the geometric stiffness is higher, but I don't think the load will be higher, just reach a given load more quickly with fewer turns of the screw.
                                                      Richard
