Re-casting LG2/Colphos 90 into plate form
Home Forums Materials Re-casting LG2/Colphos 90 into plate form
Viewing 25 posts - 1 through 25 (of 32 total)
  • #30201
    Wal Werbel
      @walwerbel59154
      #584750
      Wal Werbel
        @walwerbel59154
        Hello all.
        I was recently trying to get hold of some LG2 (or Colphos 90) but in plate form. It soon became clear that these materials are more widely available in hex or bar and that I'd find it nigh on impossible to buy as plate.
        My question is, if I absolutely needed LG2 in plate, how feasible would it be to get a foundry to melt a bunch of ingots and re-cast 'em into plate? Would it dramatically change the free-cutting/weather-resistant properties? Would it end up looking like the inside of an Aero bar?
        This is just an idle question from someone who doesn't know all that much – I'll likely go with Naval Brass (CZ112) – not as aesthetically pleasing, but available in plate and meets the hard wearing / good in a marine environment requirements. Not as free cutting, but should be OK – there are a lot of letterforms which will need to be machined using end-mills down to 0.5mm, as in the pic.
        Many thanks for your advice, excogitation etc.
        Wal.
        #584785
          Would PB102 do? if so M-machine do that in sheet form as well as flat strip
          #584787
          Wal Werbel
            @walwerbel59154
            Hi Jason,
            I looked at PB102 – with a machinability rating of 20% (poor) and requiring copious flood (of which I have but a meagre trickle) I get the feeling that I'd be fighting a losing battle using the tiny end-mills.
            Wal.
            #584788
              What size & thickness pieces do you need?
              Edited By JasonB on 09/02/2022 16:26:27
              #584789
              Wal Werbel
                @walwerbel59154
                One off – 582 x 98 x 6mm (thickness can be greater, up to 10mm)
                Admittedly an odd size.
                Wal.
                Edited By Wal Werbel on 09/02/2022 16:30:35
                #584790
                  They do LG2 block 11mm thick and price by teh 25mm x 25mm square, may be worth e-mailing lynn to see if the blocks are big enough to suit your needs.
                  #584793
                  Luker
                    @luker
                    Hi Wal,
                    They shouldn't have a problem casting that, and you won't get any loss of machinability or corrosion resistance (in fact the machinability will be better). If the surface area is large compared to the volume you unlikely to get draw holes, as is the case with your plate. Plates are easy to cast when compared to large volume – small surface area components like cylinders or bars. This is of course assuming the foundry is even remotely competent. Cost is of course another matter.
                    Hope this helps…
                    #584796
                    Wal Werbel
                      @walwerbel59154
                      Cool, well spotted Jason.
                      I'll drop 'em a line to see what's available.
                      Cheers!
                      Wal.
                      #584797
                      Wal Werbel
                        @walwerbel59154
                        Posted by Luker on 09/02/2022 16:40:40:
                        Hi Wal,
                        Hope this helps…
                        Many thanks for that info. Hehe – ah yes, it's always the cost that decides..!
                        Wal.
                        #584821
                          I don't think they will cast plate as you know it. Plate is rolled to get the nice smooth finish either side. Casting will be rough and need machining down flat both sides.
                          Or could you machine those individual letters out of slices of round or square bar of suitable size?
                          #584823
                          Nick Hughes
                            @nickhughes97026
                            These stock Leaded Bronze sheet/plate and flat bar :- S&D Non-Ferrous
                            Might be worth giving them a call.
                            Edited By Nick Hughes on 09/02/2022 22:15:54
                            #584836
                            Wal Werbel
                              @walwerbel59154
                              Posted by Hopper on 09/02/2022 21:34:16:
                              I see what you're saying – although I wouldn't mind facing off both sides, as long as the thickness is there. Machining the letters individually wouldn't work for this job – imagine a long flat bar that gets inlaid into a paving slab – kind of a heritage way-marker.
                              #584837
                              Wal Werbel
                                @walwerbel59154
                                Posted by Nick Hughes on 09/02/2022 21:57:35:
                                Thanks Nick – Yep, I dropped them an email last week – the closest they can do is PB102 or CZ112.
                                #584838
                                Luker
                                  @luker
                                  Hi Wal, is this a commercial (paid-for) job? There is another option that may be worth considering.
                                  #584843
                                    If you are going the cast route then why bother with getting a flat bar cast.
                                    CNC the whole thing including letters from some pattern board and have it cast with the letters as most nameplates are be it with pattern makers letters or these days a CNC pattern. I'm just doing one for a friend.
                                    Edited By JasonB on 10/02/2022 07:17:09
                                    #584860
                                    noel shelley
                                      @noelshelley55608
                                      Casting that in high definition is easy ! Gun metal or brass ? Serifed letters in a size of your choice from 1/2" to a 4" in plain. Flat background or raised border ? Noel.
                                      #584872
                                      Wal Werbel
                                        @walwerbel59154
                                        Thank you fellas,
                                        Yes, of course – that's the straightforward approach, just make the pattern and get it cast. So the next part of my question is how much detail can I expect to lose? As mentioned, I know bugger all about casting and what can be done nowadays. Some of the letterforms get quite small (5-6mm in height, occasionally with serifs) and my customer would be after a specific background 'texture' which may or may not be problematic – I'll post a couple of example pics of bits and pieces I've done for him below.
                                        But of course – if bronze is absolutely what's required then casting it is the way to go, I think that in his mind's eye my customer is seeing a rougher, pitted finish and a greater loss of detail than he'd perhaps want – CNC machining it takes away some of those perils of casting.
                                        Paving Inlay Process
                                        #584876
                                          Noel would be better places to say for sure but I would say you will loose some fine detail with sand casting particularly your textured backgrounds, if the part were smaller than investment casting would be a possible option.
                                          You would also need to machine some draft angle onto the sides if the letters which either means a 3D toolpath with many fine step downs or using the edge of a tapered engraving tool with single flute, both options considerably add to machine time.
                                          #584963
                                          noel shelley
                                            @noelshelley55608
                                            pictures8 099.jpgpictures8 098.jpgA woven background as in old AA badges is copied – every thread ! A showmans loco 3"long in relief, even the lettering round the canopy can be read – if your eyes are good enough. Using mansfield sand you will loose almost nothing BUT it will look cast. Check out any shot of the Fred Dibnahs MADE IN BRITAIN . Look closely and you will see 2 tiny dot marks for drilling, cast in ! Foundry lettering has a good draft as part of it's design. There are 3 standard fonts, flat face serif, 1/2" up, Flat face 1/4" to 4" and sharp face 1/8" up. The bevel gear illustrates the detail that can be achieved ! The 2nd image show the edges rounded due to polishing. Noel
                                            PS this is over 20 years old and was done for OLD reeves ! N
                                            Edited By noel shelley on 10/02/2022 23:57:05
                                            #584973
                                            Alan Charleston
                                              @alancharleston78882
                                              Hi Wal,
                                              If this is for a specific job with only one letter size, it might be easier to find the minimum size circle which will fully circumscribe the biggest letter and buy a length of round bar of that diameter. LG2 is easily parted off so if you faced the end of the bar and parted off a 6mm length you could then loctite the faced side onto a piece of aluminium as shown in your photo. Repeat until you have the number required and face them off using a fly cutter. Then it's just a case of milling out the letters.
                                              Alan C.
                                              #584976
                                                There is certainly some loss of crispness in the castings Noel shows, crumbling edges of the sand are often the cause just look around the back half of the rear wheel or where the sand broke away between the front wheel and the "E" of Reeves. It would really depend on what your client will accept
                                                If the part is indeed going to be walked on then Loctite may not be ideal, It's OK on a decorative part as I've done similar with epoxy but in those cases it would only have been subject to light handling. These letters were "roughed up" to make them look more like they were cast.
                                                PS that is not lettering stuck onto aluminium, just the machined background reflecting light differently
                                                Edited By JasonB on 11/02/2022 07:26:13
                                                #585014
                                                noel shelley
                                                  @noelshelley55608
                                                  The reason I used the reeves casting was to illustrate the detail it is possible to get. The pattern was far from perfect and the reason I still have this is it was the reject and no rectification work was done on it . If this casting was viewed from 3' away rather than 3" then the imperfections would hardly be visible and set in a pavement not noticed at all. Obviously it depends on what the customer wants or will accept – A modern CNC made item or a traditional casting ? I like Jasons mention of roughing up to make a CNC job look like a casting ! Noel
                                                  #585037
                                                  Wal Werbel
                                                    @walwerbel59154
                                                    Hello all,
                                                    Some good information here. Thanks for posting those images Noel – very helpful.
                                                    I did some tests a while back for a company who were after a bit of custom signage. That was CNC'd but I added a bit of patina to get a cast look (electrolysis and then acid) – it was in aluminium (pic below) – I get the impression that my customer's after crisp lettering for this job – perhaps I go with CNC-ing the brass and adding patina to the floor where the texture sits?
                                                    #585063
                                                      It might be worth buying a small piece of pb102 and seeing how it machines, although most sites as it is 20-25% machinable that is when compared with hard brass as being 100% and brass is very easy to machine. Different if they said it was 20% of tool steel!
                                                      As Noel say a lot will depend on how your client looks at things, I always spot things on photos of my work that I did not see in the workshop! The link I posted when I first mentioned casting the whole thing all look acceptable as nameplates and not a lot different to that red and black infilled one of yours. The paint hides the cast or machined surface so harder to tell the method used
                                                    Home Forums Materials Topics
