Thick walled copper tube
Home Forums Materials Thick walled copper tube
  • #395797
    Keith Rogers 2
      @keithrogers2
      Hi, I,m currently helping a friend progress with building a Tich loco he started 40yrs ago. We are close to assembling his boiler parts but have got stuck trying to source some thick walled (5/32 OD x aprox 1/16 ID) copper tube for the hollow stay. I can find some 22g but as this has to be threaded 5/32×40 it only leaves 12thou at the root — not good for a boiler stay
      I know it was available 'cos I have it in my own Tich boiler (which was not built by me)
      Any suggestions where I might get some would be much appreciated.
      Keith.
      Keith Rogers 2
        @keithrogers2
        #395833
        Nick Clarke 3
          @nickclarke3
          As a different approach what about an external feed (between the frames??) to the blower and add an extra solid stay?
          #395843
          duncan webster 1
            @duncanwebster1
            If using an external feed I'd put it right next to the boiler under the cladding to keep it hot. I've seen at least one loco at our track with water droplets coming out of the blower as the feed pipe was running in fresh air. Two of my locos are done as suggested successfully
            #395860
            D.A.Godley
              @d-a-godley
              Would suggest you try John Keatley Metals Ltd , Birmingham, 0121 236 4300
              They are most helpful , and I am sure will be able to supply this .
              #395870
              Weary
                @weary
                Or consider using 3/16 x 16swg (= .064" or 1/16" wall thickness) which is commonly available? Adjust threads and fittings (bushes etc.) to suit 1/32 diameter increase.
                Phil
                #395871
                John Baguley
                  @johnbaguley78655
                  Hi Keith,
                  I finished off a couple of Tich boilers for someone some years back and had the same problem. I just used ordinary thin wall copper tube and silver soldered bronze ferrules on the ends. One was threaded to screw into the blower valve and the other threaded 1/4 x 40 to screw into the bush in the front tube plate. You could also just silver solder the tube into the blower valve. I did that on my Helen Long boiler.
                  Not a good photo but you can see the blower stay at the bottom. You don't need the double threaded fitting on the smokebox end. The end of the ferrule is countersunk and the blower pipe just fits straight onto that.
                  Edited By John Baguley on 11/02/2019 23:44:55
                  #395917
                  paul rushmer
                    @paulrushmer83015
                    Keith
                    3/16 16swg copper tube is available from Blackgates in short lengths delivery normally by return.
                    Hope this helps
                    Paul
                    #396025
                    Keith Rogers 2
                      @keithrogers2
                      Hi guys.
                      Thanks for all the replies, most helpful.
                      At the moment it's a toss-up between JB's idea or increasing to 3/16.
                      Unfortunately Duncan there is no space between the boiler and the cladding on the Tich, I don't think LBSC believed in insulation sad.
                      Thanks again .
                      Keith
                    Home Forums Materials Topics
