Steel for making tool holders
Home › Forums › Materials › Steel for making tool holders
  • #278669
    Matt Harrington
      @mattharrington87221
      I'm about to make a few Tripan tool holders for a toolpost I have. What would be the suggestion for the type of steel to use for these or does it not really matter. I was thinking of ground stock to the correct overall size but not sure what grades to go for.
      Matt
      #29675
      Matt Harrington
        #278677
        pgk pgk
          @pgkpgk17461
          I made a bunch of these a while back.. ordinary cold rolled bar. they seem to work fine.
          #278721
          Thor 🇳🇴
            @thor
            I used ordinary black mild steel to make my toolholders. They might not last as long as hardened toolholders, but when they afre worn I can just make some new ones.
            Thor
            #278749
            Chris Evans 6
              @chrisevans6
              You won't wear them out if you use black rolled bar. Avoid "O1" ground stock it is not easy to machine and expensive for no real gain.
              #278753
              John Haine
                @johnhaine32865
                IIRC ground stock is either flat plate of square bar, so might not be available in the size you want anyway. As Chris says, it's tough to machine for no significant benefit. Better to use black rolled bar and if you are really keen you could always case harden. But what's going to wear anyway?
                #278760
                Matt Harrington
                  Thanks guys, you have answered my question and now I shall source some mild steel @ 30mm x 50mm – this being the section of the Tripan holders I want to make.
                  Matt
                  #278898
                  Tony Pratt 1
                    @tonypratt1
                    Matt,
                    I too would go with black rolled bar, I also suggest you 'rough out' all the main features on each tool holder to relieve any stresses in the material then finish M/C each block for the best results.
                    Tony
                    #279010
                    Ian S C
                      @iansc
                      With hot rolled bar you won't find much in the way of residual stress.
                      Ian S C
                      #279196
                      John Reese
                        @johnreese12848
                        You might find this video series useful.
                        #279200
                        thaiguzzi
                          @thaiguzzi
                          Any old steel to hand will do. I've even got 5 in aluminium (ran out of steel stock)…
                          #279604
                          Matt Harrington
                            Posted by John Reese on 21/01/2017 01:10:18:
                            Thanks John – a tutorial for the holders I am after!! Couldnt be better. I see he uses plain carbon steel ground stock.
                            Matt
                          Home › Forums › Materials › Topics
