Cast Steel, Nickel Steel, Phos Bronze?
Home Forums Materials Cast Steel, Nickel Steel, Phos Bronze?
  • #275961
    PaulR
      @paulr
      A few years ago someone gave me some blocks and thick flats of a silvery looking steel which he described as 'cast steel'. I believe they used to work this stuff with a laser or water cutter in his engineering business. What's it usually composed of and is it any use for model engineering?
      I also have some approx 1" dia steel bar which despite being well over a decade old shows no hint of rust or corrosion. I don't think it's stainless, it has a very slight hint of greeny-yellowish colour to it (and no it's not brass before some wag chips in with that 😀 ) I think someone once told me it was nickel steel…
      And finally, I have a few blocks and tubes (the latter about 2" dia) that I think are phosphor bronze – it looks more yellow than brass and seems difficult to machine. What, if anything, is it likely to be useful for in modelling?
      #29668
      PaulR
        @paulr
        #275974
        Mark C
          @markc
          They could be anything but the brass is probably just that or maybe aluminium bronze – if it was phos it would be a rather nice copper red. If you have a helpful scrap dealer near you they might zap the materials with a composition tester which will give the material from it's chemistry.
          Mark
          #276003
          Brian H
            @brianh50089
            Posted by PaulR on 05/01/2017 21:54:54:
            It is possibly aluminium bronze. A good test of its suitability is to try silver soldering it; if the solder runs everywhere but doesn't stick then it is likely to be al bronze. Still useful for some jobs though.
            Brian
            #276010
            Rik Shaw
              @rikshaw
              If it is of a silvery/grey hue with a hint of green/blue then it might be nickel. I have a bar of thisand thats why yours sounds familiar. I posted about it on here quite a long time ago and several identified it as nickel and that it may have been used as part of the gubbins in an EDM (spark erosion) machine. Mine is approx. 7"x1.5"x.5" from memory as I have put it in one of those "safe" places that I have forgotten about……….Rik
              #276036
              Martin Kyte
                @martinkyte99762
                When built my Quorn the rotating base material was cast steel and it machined really nicely. Sort of cast iron without the dust. I assume it was just a low carbon steel that had been cast rather than drawn so no skin stresses.
                regards Martin
                #276039
                Michael Cox 1
                  @michaelcox1
                  Another possibility is that it is Monel, an alloy of copper and nickel. This is similar in appearance to stainless steel.
                  It is corrosion resistant but any corrosion that does form will be greenish ( both copper and nickel hydrated salts are green).
                  It was used for special purposes such as chemical plant etc . but most commonly it was used for items in contact with seawater such as propellors and propellor shafts.
                  #276161
                  PaulR
                    @paulr
                    Thanks for the replies. What I described as phosphor bronze can be soldered; I made a tiny boiler from part of one tube a few years ago (https://www.youtube.com/watch?v=9tpH0FAYScQ). Maybe it's some type of brass but it is truly horrible to machine it does remind me of the few pieces of bronze I've ever worked with.
                    If the 'nickel steel' is Monel or some other nickel alloy, does it have any application in model engineering (I'm not planning on building a sea-going boat!)? I'll saw a bit off the bar and have a play with it. I don't know of any scrap dealers in the area – which is a shame as I'd love to rummage through their bins.
                    I'll have to try machine some of the cast steel although it's in flat slabs or chunky blocks that will take some hacksawing to fit in the lathe.
                  Home Forums Materials Topics
