Brass Tube
Brass Tube
Home › Forums › Materials › Brass Tube
  • #275732
      Seeking 3/8" O/D brass tube with a 1/16" (or 0.065&quot wall diameter.
      The usual suspects only seem to stock 0.035" wall tube.
      Sadly google gets confused by the fractions as most sites stock 3/8" AND 1/4" OD tube, but with thin walls.
      I found one source in the US! There must be a UK source as I have a small piece in my workshop.
      Ideally as a cheap (it doesn't need to be super long lasting) alternative to oilite bushes.
          There are tubes designed to fit into one another – probably what you were finding. If you soldered one inside another using whitemetal if it wore through the bearing properties would improve. laugh
          #275737
          Phil P
            @philp
            #275758
              Posted by Phil P on 04/01/2017 18:29:20:
              Macc Models on here have it listed.
              https://maccmodels.co.uk/materials-metal/brass-sections/brass-tube/16g-brass-tube/3-8-x-16g-brass-tube.html
              Phil
              Excellent, thanks Phil
                Posted by Neil Wyatt on 04/01/2017 18:01:13:
                Seeking 3/8" O/D brass tube with a 1/16" (or 0.065" wall diameter.
                Might get better results if you specify wall thickness devil
              Home › Forums › Materials › Topics
