Bench Grinder Bush
Bench Grinder Bush
Home › Forums › General Questions › Bench Grinder Bush
  • #647520
    Russell Allsop
      @russellallsop49444
      img20230605090004 (1).jpgThe bush/clamping plate on my bench grinder broke when trying to remove one of the wheels as pet the attached pics.
      I'm thinking of machining a new one can someone advise me as to the following;
      1. Can the part be made out of aluminiun or brass
      2. Do I need to replace the part on the other side in order to balance the grinder
      3. How tight should the nuts be holding the wheels on the grinder shaft.
      Your advise would be appreciated.
      #29216
      Russell Allsop
        @russellallsop49444
        Bench Grinder Replacement Bush
        #647523
        Baz
          @baz89810
          I have seen many Far Eastern six and eight inch bench grinders with pressed steel flanges so I personally wouldn’t worry about using ally or brass but no doubt the purists will say they should be steel of a certain grade, I cannot see any reason to replace the one on the other side, as for tightening the wheel, it must have blotters either side and just nipped up enough to stop it slipping. Please note that this is just my opinion not a recommendation and it’s up to you to decide if it’s safe.
          #647526
          David George 1
            @davidgeorge1
            Aluminium is suitable for one of these. Many are made of aluminium from new.
            David
            #647534
            noel shelley
              @noelshelley55608
              Like Baz, just use steel, no you don't need to replace both, and the blotters, as the name implies blotting paper or something like it will work. Having had great trouble with badly balanced wheels it might be worth trying to balance the wheels, though this would need a different type of side plate and a simple balancing way ! Most if not all grinders have left and right hand threads that should keep the wheel tight. When you have it all together, stand to one side as you turn it on and leave it running for 10mins, does it vibrate badly if yes then it is out of balance Please be careful ! Noel.
              #647540
              Baz
                @baz89810
                Cornflakes packets are ideal for blotters if you need to make any and do as Noel says, stand out of the line of fire when you turn it on. If it is badly out of balance you can loosen one wheel and rotate it say 90 degrees, re tighten and try again, keep rotating the one wheel at 90 degree intervals and trying it, hopefully you will end up with the heavy sides of the wheels opposite each other which should reduce vibration. In the good old days abrasive wheels were made to much better standards than they seem to be now.
                #647541
                Nicholas Farr
                  @nicholasfarr14254
                  Hi Russell, whatever metal you use, it must be the same diameter as the one on the other side, I don't mean to the last micron, but you should be able to get it to less than 0.5mm difference.
                  Regards Nick.
                  #647542
                  Clive Brown 1
                    @clivebrown1
                    It's important to make the new flange with gripping diameters the same as the old one, to avoid stressing the wheel when tightening the nut. I've found turning the wheel small angles 0n the shaft before final tightening to be a method for reducing sideways wobble of the wheel rim.
                    #647553
                    bernard towers
                      @bernardtowers37738
                      As Noel says stand to one side when turning on this is the time a lot of wheels break up and as for tightness hand tight plus less than half a flat the opposite nature of the threads does the rest
                      #647559
                      Clive Foster
                        @clivefoster55965
                        Further to what Clive Brown says about gripping diameters the proper gripping rim width is pretty narrow.
                        Maybe 1/4" or so.
                        Some of the economy range grinders have very poorly designed flanges with drastically excessive gripping flange widths. The simple pressed ones can be horribly bad in that respect. Often seriously less than flat too.
                        I have a bar of dreadful, almost too soft to turn, aluminium that is steadily being used up for wheel flanges and the like. I figure a nice soft surface on the gripping bit is a good thing. Besides I have to do something with the stuff even if it owes me nothing having been given to me by a pal notorious for not letting anything go for free. Wonder why it escaped!
                        #647627
                        Russell Allsop
                          @russellallsop49444
                          The bush is 70mm diameter and appears to be a plated casting, based on the advise received I will make a identical bush out of aluminium (easier to machine on my mini lathe) and proceed with caution for the first run, many thanks for the advise.
                          #647636
                          ega
                            @ega
                            The HSE guide Safety in the use of abrasive wheels is worth reading even if it does not necessarily bind amateur users:
                            https://www.hse.gov.uk/pubns/books/hsg17.htm
                            Steel is the optimum material and stainless will avoid the absorbent "blotters" promoting rust on the flanges.
                            #647638
                            Nicholas Farr
                              @nicholasfarr14254
                              Hi, I do have a summery of wheel mount procedures in an album Wheel Mounting which should be followed by everyone regardless of home or work use.
                              Regards Nick.
